Scoop Bins + Midtop problem - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > PA Systems
PA Systems A forum for discussion of all parts of a sound reinforcement or DJ system: loudspeakers, mixers (desks) etc.
Old 24th July 2007, 11:13 PM   #11
Speakerholic
Cal Weldon's Avatar
What slope is the XO?
planet10 needs your help:
Let's help Ruth and Dave
Old 25th July 2007, 02:53 AM   #12
crissty is offline crissty  Greenland
Foxx510
Does it happen to excite the mids cabinet, havent heard like that anything before, the midtop enclosure is tuned to 45Hz.
C/o is 24db linkwitz set @ 160hz & 2.4Khz.
Still very confused why & how is it happening.
Old 25th July 2007, 02:57 AM   #13
Banned
Originally posted by crissty
Foxx510
air pressure - load your mids in a horn (if the drivers are suitable)
Old 25th July 2007, 05:41 AM   #14
I'd simply position them a little further away from the scoops. And the fact that your clothes move to the rythm is not really bad, ist it ?
Are you using these for disco or live music ?
Charles
Old 26th July 2007, 10:03 AM   #15
Charles
give some idea how should the Midtops be positioned, should it not be on the top of scoop bins.
yes it is for the DJ Setup, now i have tested it outdoors.
Old 26th July 2007, 10:15 AM   #16
Foxx510 is offline Foxx510  Australia
I would try a higher tuning on the top boxes maybe, but you should see if it is a particular frequency setting the top boxes resonating.
Old 27th July 2007, 11:10 AM   #17
OT: ohh.. my.. god... that is one incredibly well built and beautiful PA system Click the image to open in full size.
Old 27th July 2007, 11:21 AM   #18
With some disco system that I have (though much much les beefy than yours) we often "flew" the tops and placed the woofers close together. Stereo reproiduction of bass wasn't that good anymore that way but punchg was increased due to mutual coupling.
The tops might be built as closed box of quite small volume this would reduce cone-movement from external SPL as well. Although you would loose the possibility to use them "stand-alone" in situations where the big bass-bins aren't need.
Charles
Old 27th July 2007, 02:53 PM   #19
Charles
Old 27th July 2007, 02:57 PM   #20
[/B][/QUOTE]
Thats the reason i have buit it, and tuned to 45Hz, so i would be able to use it as fullrange in small places.
can you post some pictures
A.S.S scoop bass bin plans WANTED Bull Subwoofers 5 2nd July 2013 10:03 PM
I designed my bass and need a midtop... robotnation Multi-Way 4 12th August 2009 11:47 PM
Empty 18 inch scoop bass bins WANTED!!! Bull Swap Meet 4 2nd June 2005 02:05 AM
Help me with SCOOP bracing . darkm4n Multi-Way 2 20th January 2004 09:45 PM
Scoop comparation darkm4n Multi-Way 2 14th January 2004 07:05 PM
Copyright 1999-2017 diyAudio
