| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Musical Instruments Music recording gear and everything that makes music |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
What causes it? I always see it on older guitars and such... the chrome plated parts like the bridge corrode, pit, dull, etc. is it moisture? can it be replated/repaired easily or is it just cheaper to buy new?
While you're at it...don't forget to upgrade the lamp cord on your... lamp. Have your light bulb reproduce light faithfully, finally allowing you see light the way it should be seen! Bring out the natural performance of your table lamp. It will offer greater warmth, detail, brilliance, definition and speed by providing wider bandwidth and reduced skin effect. girl who feel nuts better than girl who feel crazy |
#2 |
Look at it under a microscope and you see what's going on....
You can have the chrome redone offcourse, but the first thing that I would try is chrome polish and wax...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once...... http://www.41hz.comhttp://www.octopusamps.com/http://sound.westhost.com/http://www.t-linespeakers.org/http://www.marchandelec.com/
#3 | |
Nigel Goodwin |
#4 |
The salt in sweat is the main cause, but atmospheric contamination can also be a problem where guitars are displayed and not played. The pitting usually descends into the base metal, so replating isn't an ideal option, (if you can find someone to do it). If the guitar is a classic, then don't replace the parts, you may well affect the value. If not, you can swap them out.
If you don't want a new guitar to go this way, then the chrome, (and other metal parts), needs to be cleaned everytime you use the guitar. I used to use woodworking bit and saw blade cleaner sprayed only onto a cloth, not onto the guitar. It cuts grease and sweat, and leaves a protective anti-corrosion layer.
Al The miracle is not to fly in the air, or to walk on the water; but to walk on the earth. Chinese Proverb |
| Thread Tools | |
| repair chrome plating | audio-kraut | Analogue Source | 19 | 20th June 2006 09:44 PM |
| Chrome chassis | Prune | Parts | 2 | 18th June 2004 03:49 AM |
| Sylvania Chrome top 6SN7 tube | 6BG6GA | Tubes / Valves | 15 | 27th December 2003 03:20 PM |
| OT: Aluminum chrome plating? | thylantyr | Solid State | 7 | 24th August 2002 06:46 PM |
| Chrome Heat Sinks | more_power | Solid State | 23 | 31st May 2002 08:04 PM |
| Page generated in 0.41972089 seconds (88.73% PHP - 11.27% MySQL) with 10 queries |
