Go Back   Home > Forums > General Interest > Musical Instruments
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Musical Instruments Music recording gear and everything that makes music
Thread Tools
Old 18th September 2009, 04:39 PM   #1
Default What's a good gain range for feedback delay?
Right I'm going through a range of components of what to use for gain as feedback in a delay unit but don't particularly know what a good range is (0 < N), any reccomendations? I want a decent amount for super-dubby washouts but also fine control over the range of a normal pot' turn
Old 20th September 2009, 06:58 AM   #2
neutron7's Avatar
you want that to be adjustable. from 0 to 99% or 100% if you like to go crazy
it is one of the most important controls of a delay.
Old 20th September 2009, 09:32 PM   #3
Yeah I know hence needing an indicator of what range it should be, I'm working out what a good max gain would be with it being all useable plus a bit of sillyness.
Old 20th September 2009, 10:52 PM   #4
neutron7's Avatar
Anything over 100% will get louder as it repeats. if you ride that control you can definitely get some dubby stuff happening, but it can easily get out of control.
its good to put filters and other effects in the feedback loop as well.
anyways the whole range is useful, up to 110%
however the lower part of the range becomes almost inaudible
You could have a reverse law control on there, where most of the action is over the 50 to 110% range.
Old 21st September 2009, 12:43 PM   #5
Aah, cheers, I didn't think about inaudible signal gain so this 'reverse control law' would be quite handy; what is it and how does it work? Sorry if it's simple, I just had a quick look on google and couldn't find anything. It would be really good for fine control of gain ratio though
Old 21st September 2009, 01:29 PM   #6
neutron7's Avatar
that would be like an audio taper potentiometer, which has most of its range near the bottom, but around the other way so the fine control is at the top. I think there are potentiometers called "anti-log" but almost impossible to find. you would probably just use a linear potentiometer and make the circuit behave that way electronically.
Thread Tools
Feedback/Correction on Gain rather than input? pilli Everything Else 1 18th September 2008 09:52 AM
Gain stage with g2-feedback. jane Tubes / Valves 18 28th May 2008 09:06 AM
Feedback delay & distortion Jorge Solid State 211 6th September 2005 02:00 AM
Automatic Gain Control - 50W amp needs a good feedback schematic! styoshi Solid State 3 23rd April 2004 09:11 PM
Need explanations on WinISD Gain/phase/group delay graph Tired Multi-Way 1 23rd June 2002 05:26 AM
Page generated in 0.06826401 seconds (79.44% PHP - 20.56% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
