I'd like to build a 200 litre box with a pair of 15" drivers in it. I've narrowed the choice down to two drivers: Precision Devices PD158 and Eminence Kappa Pro 15LF-2. Plugging these into Winisd, the Eminence has the better LF response, but suffers a big dip in maximum power at 60Hz. The PD doesn't suffer this. Which would sound better (for bass guitar between 40 and 300Hz - I'll be using a pair of 10s for mid/hf) ? Would the improved response of the Eminence compensate for its lack of power handling? Thanks! attached: 2 winisd files |
#2 |
um, the attachments didn't attach...hang on, I'll try and fix them more securely...
#3 |
Is it a speaker that needs to add a "signature" to the sound, or just a speaker that has to be neutral ?
Because what matters most in your case could be the distorsion profile of the drivers.
Fostex F120A speaker pair for sale - 250€ only ! |
#4 | |
#5 |
So maybe you should pick up the PD and add a circuit to compensate for the higher rolloff point. This can be achieved by using a high Q highpass filter.
I have some Eminence Delta 12LFA, and I must say these are not good drivers. Pretty high distorsion (1.5 to 5%)
#6 |
I've heard only good things about the Emminence 15 LF, especially its lack of distortion. I have a friend who is building his bass amp using this driver and an Emminence 6" for highs.
Listen to the music through the stereo, not the stereo through the music. |
#7 |
OK, hope the 15LF is better than the 12
Otherwise, I found a very interesting driver from PD when I was looking for a big woofer : the PD1550. It has guaranteed distorsion specs (<1%, which is very good for a woofer) and a large Xmax. However I don't know how it models in vented boxes.
#8 | ||
Then again, the max SPL plot shows the PD to be 3dB louder around 60Hz. I think I'm up against the old loud/deep dilemna really. Quote:
I think for bass guitar applications the distortion spec is going to be irrelevant. Very important for music though, and 1% is excellent. |
#9 |
If you already have the Kappa pro 15 LF2, I wouldn't update it to another 15" woofer. 3dB is not a huge improvement, especially if you want something really louder.
Maybe you could use a dual Kappa pro 15LF2, or build new boxes for 18 or 21" drivers.
#10 | ||
| 4x12 Guitar cab using guitar and bass speakers help | andrewskaterrr | Instruments and Amps | 15 | 23rd April 2009 11:43 PM |
| any electric bass players? im building a bass guitar cab | KOA | Instruments and Amps | 27 | 30th April 2007 03:49 PM |
| So much choice- FR + Bass or Coaxial in OB? | inrank | Full Range | 16 | 1st November 2006 04:49 PM |
| Help with driver choice. | unitgain | Multi-Way | 5 | 2nd March 2004 10:18 PM |
| Choice of driver for El Pipe-O | Nicwix | Multi-Way | 14 | 1st July 2003 09:18 PM |
| Page generated in 0.09304 seconds (87.68% PHP - 12.32% MySQL) with 10 queries |
