T/S measurements with Speaker Workshop
Old 17th January 2003, 12:46 AM   #1
daatkins is offline daatkins  United Kingdom
Default T/S measurements with Speaker Workshop
Hi everyone,
What level of accuracy have people had with Speaker Workshop when measuring TS parameters?
For example, I recent bought two Audax HM100Z0 drivers. They are specified at....
Fs = 64Hz
Vas = 4.72l
Qts = 0.49
But they measured at (run-in for over 24 hours)....
Fs = 85Hz, 83Hz
Vas = 2.34l, 2.49l
Qts= 0.57, 0.55
I've measured several other Audax & Peerless drivers and Fs is always higher than spec whereas Vas is consistently lower than spec. Qts, Qms and Qes are all off spec but are still within the tolerances driver manufactures accept.
I'm running the 1.06 version of SW (the latest) with a Wallin Jig 2 and everything is calibrated. Impedance plots of the 4.7R and 16R calibration resisters show very good accuracy and linearity with respect to frequency.
Any ideas?
Nice one,
David.
Old 17th January 2003, 01:07 AM   #2
FrankDIY is offline FrankDIY  Canada
FrankDIY's Avatar
This is normal. Your values seem normal. Usually, worst case is 30% off
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein
FrankDIY's Audio Corner
Old 17th January 2003, 02:12 AM   #3
Thanks Francois,
That's reassuring but I've measured six different Audax drivers (3" HT080G0, 4" AP100Z0 & 5.25" HM130C0) as welll as one pair of Peerless drivers (831858) and they ALL show higher Fs and lower Vas than specified. Is that your experience?
I've always accepted 30% as being the tolerences on drivers but the Vas measurement on my AP100Z0 is 100% off!! Am I doing something wrong? I used the added mass method (using coins for weight) with the magnet side of the driver clamped down on the bench.
Nice one,
David.
Old 17th January 2003, 03:09 AM   #4
FrankDIY's Avatar
Yes, I see that often.
To give you an example, here are the specs for a Peerless 850102.
manufacturer specs:
fs 74.2
vas 3.4
qts .43
measured specs:
fs 102
vas 2
qts .52
(after my usual 100 hours of break-in)
I know, 30% is big but as long as all your drivers are close to each other this is not a problem. Cheap drivers may have 30% off the manufacturer specs but worse they may have 30% off between each other.
Old 17th January 2003, 04:14 AM   #5
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
What about Vifa classic series drivers? Do they behave the same as cheaper drivers?
Dave
Old 17th January 2003, 02:50 PM   #6
FrankDIY's Avatar
I don't think so.
By cheap driver I mean very cheap and obscur brand
Old 17th January 2003, 03:49 PM   #7
Redeye is offline Redeye
David - How much difference does this make to your enclosure design? Personally, i usually use WinISD and put the manufacturers specs in, then fiddle with volume and tuning until I get something like what i want. But, once I've built the cabinet i use the calculated port length as a rough guide and just hack bits off until it sounds right (I always trust my ears over my computer). I'm just interested to see how much of an effect this difference in measured and manufacturer data has on your preferred enclosure size?
Old 17th January 2003, 04:23 PM   #8
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
Higher Fs and lower Vas are two things that tend to cancel each other.
The following is a WinISD simulation of the two sets of numbers, stated and measured, for the Audax HM100Z0. this is for a sealed box of 4 liters.
The stated numbers are in red.
The measured numbers are in blue.
I would call this pretty good agreement with the stated specs once this thing is put into a box. Calling the F3 of the measured spec 103 Hz, I would say that the stated spec gives an F3 less than .2 of an octave lower than the measured spec.
Put another way, where the stated specs are 3 dB down, (90 Hz), the measured specs are 4.5 dB down.
For good makes like Audax and Peerless, the measured and stated specs do tend to work out this way. This is good for ported and sealed boxes. For transmission lines, maybe not so good.
Old 17th January 2003, 04:46 PM   #9
Wizard of Kelts
And just to further illustrate, here is Francois' Peerless 850102 in simulations of both published and measured specs. This is for a sealed box of 2.5 liters
The published specs are in red.
The measured specs are in blue.
At 121 Hz, where the published specs it should be 3 dB down, it is actually 4.5 dB down. This is not even taking into account a possible SPL shift with the difference in numbers.
This squares with my experience with Peerless too. It also agrees with the experience of Madisound, who measures the drivers when they come in. The Peerless model I ordered from them had different specs, but similar performance to published specs when placed in a box. In that case, it was the opposite direction-the speaker had lower fs, but higher Vas. But it all worked out when put into the box. (Actually, optimum vent tuning would shifted slightly with the new numbers-but even then, the old vent tuning would have worked OK.)
In a better world, the published specs would be a lot closer to the actual specs. But in this world, I guess we can live with the thing just working out reasonably all right in the end.
Old 17th January 2003, 06:00 PM   #10
kneadle's Avatar
I'm, indeed, building a TLine, and I'm without means to measure my drivers; that's why I bought Vifa.
Care to comment, O Kelticwizard? Or anyone?
Vifa P17WG00-06
Fs=35Hz
Qms=1.34
Qes=.58
(Qts=.4)
Vas=49.4
Xmax=3.mm
I got these numbers off the Vifa Catalogue .pdf file that Madisound has on their site. Is there a place to find a "real" measurement?
Dave
T/S measurements with Speaker WorkshopHide this!Advertise here!
Vas measurements by added-mass method in Speaker Workshop tcpip Multi-Way 26 1st June 2009 10:07 PM
Distortion Measurements with speaker workshop noodle_snacks Multi-Way 1 6th September 2006 03:28 AM
Does anyone have the a speaker workshop project with Seas 27TBFC/G measurements? owdi Multi-Way 1 3rd August 2006 04:06 AM
SPL measurements in Speaker Workshop: need help tcpip Multi-Way 7 27th October 2005 06:00 AM
Speaker Workshop vs. other software WRT measurements timsch75 Multi-Way 3 26th September 2004 02:11 AM
