I'm new to this forum and I hope I'm posting to the right place.
My question relates to Home theater and in particular to the design of enclosures. Here is the "problem", I want to build a center speaker that can be "fitted" behind a flat screen TV. the TV is not mounted on the wall so I can move the TV away from the wall a few inches. I wonder if any thoughts to building the enclosure as in the drawing, so it can be mounted in the wall behind the TV and the drivers only showing above the TV. The drivers I envision would be like parts express 264-815 (3 " mids)and 264-834 (tweeter), similar to the "cyanosure" DIY posted in parts express' website. any thoughts? Full of it? stick to other design? |
#2 |
I can't think of any reason why it wouldn't work - it's a very practical idea - as long as the box volume is correct for the selected drivers you should get satisfactory results.
Maybe just make sure the drivers have some decent clearance above the top of the TV to minimize refraction off of it.
Soft Dome |
#3 |
Greets!
Can work fine, I helped a guy with a fullrange driver rear loaded horn that hugged the wall behind his TV/equipment and did a number of both floor standing and wall hung 'pancake' speakers that blended into the wall as well as some drop-in 'panel' designs for suspended ceilings for apt. dwellers and/or basement 'rec' rooms during my building days. IIRC, Dave p-10 (a moderator here) made some with favorable results based on one my designs using 'el cheapo' 40-1197 RadioShack FR drivers several years ago. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 | |
Could I get more info on your el Cheapo Design. Thanks both for the reply, JR |
#5 |
Greets!
Sorry, I apparently I didn't keep them after the driver was discontinued here in the USA. I believe Dave made a drawing of at least one of them though if you have some or willing to get them from Canada. Actually, the Fostex FE103E would be a much better choice and its higher price is ~off-set by the fact that most folks don't feel the need for a super tweeter with it. GM
| what's best enclosure design for Coral Beta 8 Speaker ? which horn ? Schematic ? | calico88 | Full Range | 31 | 30th November 2006 07:38 AM |
| center channel speaker design | legendaryfrog | Multi-Way | 23 | 29th October 2006 08:07 PM |
| Flush To Plasma Center Speaker Design Needed | diy_subs | Multi-Way | 7 | 25th October 2006 09:14 PM |
| Help me to design the ultimate Center-Speaker | Blitz | Multi-Way | 22 | 10th January 2006 01:16 AM |
| MTM Transmission Line Design-Where To Consider Center Of Speaker | kelticwizard | Multi-Way | 4 | 8th December 2005 02:30 AM |
| Page generated in 0.09494 seconds (72.46% PHP - 27.54% MySQL) with 11 queries |
