Old 10th April 2007, 11:22 PM   #1
akunec is offline akunec  Canada
Default Measuring Ground Plane Response Outside
I'm planning on measuring the ground plane response on my speakers outside on my driveway. I will merge that response with my gated response at ~1khz. The driveway is about 20 ft wide by 10 ft long. It is tilted at about 5 degrees to merge with the pavement.
Will the tilt between the road and the pavement cause reflections that will affect my results?
Is the rough cement used for driveways a good enough reflector of sound?
Old 11th April 2007, 12:44 AM   #2
freddi is offline freddi  United States
freddi's Avatar
sure better than my muddy yard which drops behind the mic only a few feet and ramps up a hill from the other perspective -- you should be fine
http://img490.imageshack.us/img490/3...vk154161sf.jpg
star ground vs. ground plane Sebastiaan Chip Amps 15 10th May 2009 05:05 PM
Ideas for ground plane/shielding? hotbottle Tubes / Valves 7 25th March 2008 12:41 PM
Using Ground Plane on Both sides of Board? ppl Solid State 11 13th October 2006 04:14 PM
DAC Ground Plane Noise Reduction? fastcat95 Digital Source 1 3rd May 2005 05:08 PM
I discovered CDP ground plane. What should I do with it? DIAR Digital Source 18 4th December 2004 12:29 PM
Page generated in 0.05490 seconds (79.81% PHP - 20.19% MySQL) with 10 queries
