Old 9th April 2007, 04:12 PM   #1
domus71 is offline domus71  Portugal
Default dynaudio problems
Hi
it`s the first time i participate in diy.com.
I have dynaudio crafft loudspeakers, i trie to open but the units are glued to the box.
does any of you now how to open?
Vitor
Old 10th April 2007, 01:40 PM   #2
I contact dynaudio and they confirm that the drivers are glued but don`t tell me how to take the units off.
The replay was(if a driver is not working, go to a autorize dealer) they also don`t tell how to take them off.
The importer of dynaudio in Spain told me that there`s a way, he ask me why i want to take the drivers off, i told him the true and he refuse to tell me, i (should have lie to)
My idea off changing the internal wires is getting very ward!!!
Old 10th April 2007, 02:20 PM   #3
maybe you can remove the backplate and poke on the driver
I think the remove the cone&bobin&spider when they remove a defective driver, since its already defective.
Old 10th April 2007, 08:22 PM   #4
The back of the louspeaker is also glued, imagine if it`only a loose wire will they damage everithing...It`s a really
TOP SECRET LOUDSPEAKER
Old 11th April 2007, 10:07 AM   #5
obiwan is offline obiwan  Australia
I decided a few months ago to biamp my Dynaudio Special 25's using a DEQX as a crossover. The woofer came out quite OK, but there was no way that tweeter was leaving the cabinet. Like you, it felt like the tweeter face plate was glued in position.
The only way I could remove the tweeter was to take it out backwards. I had to take the inner 3 screws out and grab the tweeter from behind. Because the woofer was already out I just put my hand inside the cabinet and grabbed the tweeter from behind and pulled it out through the woofer hole.
Old 11th April 2007, 01:33 PM   #6
[The only way I could remove the tweeter was to take it out backwards. I had to take the inner 3 screws out and grab the tweeter from behind. Because the woofer was already out I just put my hand inside the cabinet and grabbed the tweeter from behind and pulled it out through the woofer hole.]
My problem is that the woofer is glued, Dynaudio confirm, but don`t tell me how to take it out!!???
Old 11th April 2007, 01:41 PM   #7
Is there a way to push through the reflex port ? Or is this a model without the reflex port on the back ?
Charles
Old 11th April 2007, 03:08 PM   #8
[Is there a way to push through the reflex port ? Or is this a model without the reflex port on the back ?]
Hi Charles
there are 2 reflex port below the woofer, but small.
Vitor
Old 11th April 2007, 03:11 PM   #9
Some information and picture.
http://www.geocities.com/shianjer/Dynaudio_Crafft.html
Dynaudio D54 leejh Multi-Way 2 24th April 2008 11:42 AM
Dynaudio vs. PHL: Which 12'' would you use? leifislive Multi-Way 0 12th November 2007 01:29 PM
Dynaudio servo Multi-Way 2 21st June 2006 06:26 AM
WTB or FS: Dynaudio D21-2 BenY Swap Meet 3 4th March 2006 10:14 PM
Dynaudio Roy Lewis Multi-Way 0 12th February 2004 11:21 AM
Page generated in 0.09362 seconds (73.80% PHP - 26.20% MySQL) with 11 queries
