Old 7th April 2007, 06:02 PM   #1
freddi is offline freddi  United States
freddi's Avatar
Default 3rd order cap-assisted sealed box -?
--don't have any small sealable boxes to test.Iin practice how close can one come to the graph below using 15" B&C plus 500uF?
60 liter box - 15" woofer
http://img65.imageshack.us/img65/521...40500ufdx7.jpg
Old 7th April 2007, 07:15 PM   #2
Pit Hinder's Avatar
Send a message via ICQ to Pit Hinder
Freddy,
you'll get quite close (though reality might require a bigger cap than the sim) - but that doesn't necessarily mean you'll like the result.
Very often these cap-assisted boxes don't really integrate well - gives you the feeling that the bass is marching at the rear of the parade, so to speak.
Pit
Old 7th April 2007, 07:50 PM   #3
freddi's Avatar
hi Pit - from limited experiements running CL that cap might sound "loose" with subjective overhang.
the low impedance case of C series with L across driver is really rough on some amplifiers and seemed* Erse steel-laminate choke was saturating and perhaps adding some tone (?) it was fun to see the choke pull and shake nearby pliers in beat with a drum's overtones
can you think of a way in AJ to fake tapped horn situtation?
Freddy
*tough call as load could trigger a "Samson" amp to rachet at relatively low drive plus boost and sharper knee affect certain things
Old 7th April 2007, 08:10 PM   #4
Did it Himself
richie00boy's Avatar
I think the Loudspeaker Design Cookbook has the formula for calculating the correct cap value. But it thinks of just one alignment, hence you need to size the box a certain size, first.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Parallel or Transistor assisted chip amp ? ashok Chip Amps 39 15th September 2008 12:41 AM
Third order sealed sub stee-b Subwoofers 10 11th March 2008 10:36 PM
Servo assisted CF LCR-filter revintage Tubes / Valves 5 9th February 2008 04:59 PM
Direct Coupled Choke-assisted Mu-stage snoopyma Tubes / Valves 1 18th April 2005 07:18 PM
ARDA - Assisted Rectangular Driver Array BAM Multi-Way 14 3rd October 2004 09:54 PM
Page generated in 0.08905 seconds (70.61% PHP - 29.39% MySQL) with 10 queries
