Everything I read says that the resistors in an LPAD must add up to the wattage the driver could see. (Say, 50W for a 50W tweeter). What I'm wondering is why in all the car audio crossovers I've seen they always use 5W resistors (on speakers that are claimed to be 100W). Reason I'm asking is I'm building another set of crossovers, and I had planned to use 50W LPADs, but I'm considering just tuning the tweeter level and using resistors instead. Also, I feel like an idiot for asking, but why are LPADs offered in impedances to match drivers (4/8/16 ohm). I mean isn't the point to leave the impedance the crossovers sees unchanged? Thanks everybody, Derrick PS - For anybody that read my previous posts, the Dynaudio drivers worked so well after I crossed them over correctly, that I went out and bought another set of them for the fronts (of my car). |
#2 | |
#3 |
Nothing to check--I just built new crossovers, and they don't have tweeter attenuation. I'm planning to add an LPAD (pot or two resistors), and wondering if I really need 50 watts worth of resistors.
As for the variable LPAD question, it became obvious when I thought about it some more. (i.e. if it was turned all the way down, you'd want it to present the same load across the inputs that the driver would have had). |
#4 | |
Imagine the following example, where I have simplified the driver's impedance to a 8 ohm resistor and the filter to a simple series resistor, just to make the point. If the amplifier delivers 9 volts, 1 volt will end up over the resistor, and 8 volts over the driver. The power in the resistor will be U²/R=1²/1=1 watt. The draver will take U²/R=8²/8=8 watts. In crossovers, similar effects occur. Most of the power ends up in the drivers, luckily. |
#5 |
Svante,
do you know what happens if you de-rate L-pad resistors? you may have an escalating failure. Also depends on the power they are using... |
#6 | |
#7 | |
Svante, if you change a 50W by a 5W. Cheers. |
#8 |
Here's what I came up with last night. It's a selectable -6dB / -9dB LPAD for a 4ohm driver. All the resistors are 10W (Dayton from Parts Express). I doubled up the 5's to make 2.5 and the 8's to make 4 ohms to increase the wattage. It'll be 20 or 30 watts of resistors on each leg of the lpad, depending on the switch postion.
#9 |
Derrick,
throw your headache pills into the trashcan. Unless you try to attenuate a PA bass, or try to bake Idaho potatoes on your resistors, 10W rating is perfectly OK. If you are a "belt and braces" man, two 10W of twice the value in parallel will last a lot longer than your eardrums. |
#10 | |
| Resistor wattage question | DeadSpeaker | Solid State | 12 | 17th March 2008 09:41 PM |
| resistor wattage? | jarthel | Pass Labs | 1 | 27th June 2007 04:14 AM |
| What wattage for resistor in attenuator | DC Dave | Parts | 1 | 5th February 2004 04:43 AM |
| How to put fixed attenuation between preamp and amp. Lpad or just resistor in series? | PUCK | Parts | 1 | 19th November 2003 03:59 PM |
| Resistor wattage in DOZ? | swede | Solid State | 3 | 14th April 2002 08:58 PM |
| Page generated in 0.10767 seconds (79.17% PHP - 20.83% MySQL) with 11 queries |
