Old 7th April 2007, 04:16 AM   #1
Default Replacing woofers/foam in Bang and Olufsen speakers
Hey Guys,
I have a pair of b&o cx100's that came along from the seller with an older receiver I wanted. The woofers have foam rot, which is very common with this model, especially ones over 12 years old like mine. I could just refoam them myself at $8 a pair, but I was curious about the possibility of fitting in new woofers. The problem is, the woofers are 10cm with square flanges, and I'm having a tough time finding 10cm woofers let alone ones with square flanges (they aren't those rounded off square ones you often see). The only woofer so far I've found that looks like it might fit is a 4" goldwood on parts express, but at only $7.20 each I'm not sure they'd sound any better than just refoaming the originals even if they did fit. So do you guys have any suggestions?
I'm including 2 pics of the speakers so you can see the woofers.
Thanks,
Austin
Old 7th April 2007, 04:33 AM   #2
Ok, think the pic might have been too big to load maybe...
trying again.
Old 7th April 2007, 04:38 AM   #3
Hmm, I just noticed there's a 4" Audax woofer on parts express that doesnt have the right shape flange, but the specs are identical to the b&o speaker - 6ohm and min freq. of 64 Hz. I wonder if it's basically that woofer but with a different flange. I see on Madisound there are two other 4" Audax drivers that look like they have that square flange shape.
http://www.madisound.com/pdf/audax/hm100z2.pdf
Old 10th April 2007, 05:46 AM   #4
Are square flanged 4" drivers really that rare? I thought someone on hear would know some companies that make them.
Austin
Old 10th April 2007, 01:13 PM   #5
Generally the higher the quality of a speaker the more you must
use the original drivers, so refoaming seems the only proper option.
If you didn't like the speakers in the first place, then depending
on the internal crossover complexity new drivers are possible.
/sreten.
Old 10th April 2007, 05:57 PM   #6
Thanks for the reply Sreten! I actually really like the way they sound even with the foam missing, as I think they sound better than my Infinity Primus HT speakers. Since many speaker builders on here wouldn't consider this a high quality speaker but just an overpriced one, I thought they might be able to suggest a drop-in replacement driver that might sound even better. Nevertheless I have ordered the foams and am waiting for them in the mail.
Austin
Bang & Olufsen Help!!!! Deano Parts 6 5th March 2009 05:46 AM
bang olufsen help N-Brock Multi-Way 3 31st August 2008 05:57 PM
Bang & Olufsen Remote 405man Everything Else 1 2nd January 2004 11:55 AM
Bang & Olufsen Loudspeakers zx3chris Multi-Way 15 9th December 2003 06:53 AM
Page generated in 0.10132 seconds (75.18% PHP - 24.82% MySQL) with 11 queries
