Nominal impedance Znom 4 Ù
DC resistance Re 3.1 Ù Voice coil inductance Le 0.22 mH Resonance frequency fs 55 Hz Mechanical Q factor Qms 2.2 Electrical Q factor Qes 0.57 Total Q factor Qts 0.45 Mechanical resistance Rms 2.7 kg/s Moving mass (incl. air load) Mms 17.4 g Suspension compliance Cms 0.48 mm/N Effective cone diameter d 124 mm Effective piston area Sd 120 cm² Equivalent volume Vas 9.8 l Force factor Bl 5.7 Tm Recommended frequency range |
#2 |
Zuki,
download winisd pro. plug in the #'s and it will tell you what size box to make. How did the other project work out? Subwoofer wasn't' it? Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#3 | |
#4 | |
b 1(2) |
#5 |
2(2)
#6 |
the person who is using the driver has them in a door of infinity 35.
claims the speaker does not go low enough in the bass. i have found when ib installing. some drivers actually end up with too low of a resonance freq. causing the speaker to sound weak in upper bass range. so i was wondering what size box this driver required to best performance, i hate converting litres to cubic feet.
#7 | |
i put a photo of the subwoofer up i think. they turned out really nice. getting ready to make another set for myself. |
#8 |
Hi, around 0.15cuft / 4L to 0.3cuft / 8L,
#9 | |
2) convert xxx litres to cubic feet 3) Search 4) Magic! Works with loads of other units too... |
#10 | |
so the woofer is not really an ib driver it seems. thank you. |
| Minimum size for open baffle driver? | Javachip | Multi-Way | 2 | 28th June 2007 12:06 PM |
| Driver Size Thoughts | theNoid | Multi-Way | 9 | 11th September 2005 04:05 PM |
| Help installing driver when cutout wrong size | morbo | Multi-Way | 19 | 9th February 2005 02:43 AM |
| How to measure driver size? Dimensions + standards etc | VvvvvV | Multi-Way | 4 | 9th October 2004 09:25 PM |
| Page generated in 0.11637 seconds (81.71% PHP - 18.29% MySQL) with 11 queries |
