Old 3rd April 2007, 03:33 PM   #1
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Default Noise on speaker when car is on
I've REALLY tried to search but didn't find nothing that can help me..
I've installed a quintus car amplifier (http://www.mchammer.it/Quintus1800.htm) and run all ok when the car is turned off.
But when i start the car i hear a "weeeee" from the speaker that go up with the rpm..
How can i remove it?
Old 3rd April 2007, 05:12 PM   #2
myhrrhleine's Avatar
Really can't troubleshoot across the net,
but my first guess would be ignition noise.
Try filtering the power better.
Just because you can't hear it doesn't mean no one can.
Old 3rd April 2007, 05:48 PM   #3
zigzagflux's Avatar
Ah yes, wonderful alternator whine. An extremely common problem.
First thing to check is the grounding of your head unit and amplifier. Many unibody cars have poor continuity of their metallic parts, so what you think is a good ground is likely not.
It is 99% sure not the amplifier's fault. Running a heavy cable back to the battery negative is also NOT a good solution, though it may help to prove out the problem. Technically, the alternator chassis is true ground anyway.
Your best bet may be to find a chassis bolt somewhere. What kind of car?
Old 3rd April 2007, 06:38 PM   #4
MaXiZ's Avatar
So connect the ground directly to the battery may not be the solution. right?
Anyway my car is an Alfa Romeo 156
Old 3rd April 2007, 08:46 PM   #5
zigzagflux's Avatar
Silly American, doesn't know much about Alfa Romeos.
Running a cable to your battery post is a simple test to verify you indeed are dealing with grounding issues. Whine would be expected to decrease. Long term it's not recommended, as USUALLY the resistance with a short lead to car chassis is less than that obtainable with a cable run all the way up to the front of the car.
Hmmmm. Of course, Alfa could be a midengine design, which means amp is in the front of the car, engine in the rear. It's all the same.
Point is, verify you are using a solid, beefy ground for the amp. Short cable, preferably a bolted connection. Clean up the paint down to shiny metal.
You ain't the first one, my friend.
Old 3rd April 2007, 09:55 PM   #6
edjosh23's Avatar
I agree that it is definately a grounding problem. From the car audio I have done I would suggest checking your amp ground. Making sure you sanded all the paint down where you are connecting to the body. Check and make sure that your voltage across your amp, using your ground, is the same as the battery. If there is a difference your problem is with your amp grounding. If it is about the same, check your head unit for grounding issues.
Josh
Old 4th April 2007, 06:49 PM   #7
MaXiZ's Avatar
I've connected the ground directly to the battery (about 2mt of wire) and the "weeeee" is nearly gone. I can hear it just a litle!
Old 4th April 2007, 07:49 PM   #8
edjosh23's Avatar
A little DC offset from the amp is not bad. Since most of the noise is gone that means you need to better ground your amplifier. As zigzagflux said, beefy, short ground cable to well sanded metal.
Josh
Old 4th April 2007, 07:57 PM   #9
MaXiZ's Avatar
ANYWAY THANKS TO ALL FOR THE HINTS! REALLY THANX!!!!!
As always here i can find an answer to any question.
Tubelab SE buzzing noise from the speaker Evenharmonics Tubes / Valves 7 18th July 2009 02:08 AM
Noise thru speaker when turning off Dan2 Car Audio 4 4th November 2006 09:46 AM
noise from bass unit of speaker ClassA Solid State 3 22nd November 2005 03:03 PM
Anti-noise sub/bass/mid speaker paulspencer Multi-Way 18 24th February 2005 05:37 PM
noise in right speaker when engine on crazyinjun Car Audio 13 6th May 2004 11:34 PM
Page generated in 0.10843 seconds (76.66% PHP - 23.34% MySQL) with 10 queries
