Im using a calibrated panasonic condenser mike and im considering buying an m-audio fasttrack pro. its a usb soundcard that also is a mike preamp and supplies phantom power to it. However, it supplies 48v of phantom power. Is that too much for the mike?
Thanks |
#2 |
Most sound cards will supply phantom power in the mic-in jack However, the software you are using for frequency measurement may not take readings via the mic-in. For example speaker workshop uses the line-in jack on the soundcard - requiring you to separately pre-amp your mic to bring it up to a line level input for recording.
#3 |
If what you're after is a mic impedance converter / line driver that will plug into any mic pre that supplies 48V Phantom power, supplies power to the capsule and converts the high impedance of the capsule to a low impedance to feed to a mic preamp (the type you plug most studio or measurement mics into to increase the signal level) then have a look at this:
http://www.homerecording.com/bbs/sho...1&page=1&pp=25 It's a whole thread on modding Behringer's ECM8000, but really it's all about making a new mic using the ECM8000 style body / casing and a panasonic (or similar) capsule.
If it ain't broke, break it. |
| Phantom Power might be Bad? | mistermisfit | Solid State | 12 | 10th February 2010 08:22 PM |
| phantom power for condenser mic | patknk939 | Everything Else | 5 | 21st September 2008 07:07 PM |
| reducing phantom power | Sillyboy | Everything Else | 3 | 5th June 2006 03:31 PM |
| DEQ2496 for phantom power? | mazeroth | Multi-Way | 10 | 5th January 2006 04:51 PM |
| Using the phantom power | Gabevee | Instruments and Amps | 2 | 29th July 2005 05:32 AM |
| Page generated in 0.08116 seconds (70.94% PHP - 29.06% MySQL) with 10 queries |
