Old 2nd April 2007, 02:09 PM   #1
sploo is offline sploo  United Kingdom
Default Monacor MCE-4000
I've seen Siegfried Linkwitz's instructions for using the Panasonic WM-61A mic capsule, and (from some searching this forum) I've found that the Monacor MCE-2000 was the same as the WM-60AY, but neither of these parts are now available.
Additionally, there was apparently an article on making a mic using the MCE-2000 on the Monacor website. This too appears to have gone, and I've had no response from an email asking them for a similar doc on the MCE-4000.
So, does anyone have step-by-step details of how to build (and power) a mic based on the Monacor MCE-4000 capsule? Is the MCE-4000 the same unit as the WM-61A and/or could it be used in the same way as Linkwitz specifies?
Linkwitz's mic details here: http://www.linkwitzlab.com/sys_test.htm#Mic
MCE-4000 details here: http://www.monacor.com/int/en/produk...pr=EN&typ=full
Old 2nd May 2007, 09:18 AM   #2
*BUMP*
Anyone? No one?
Old 2nd May 2007, 10:22 AM   #3
Juergen Knoop's Avatar
I build a microphone a few years ago with a eletret capsule (don't know which one)
it was simple and should be the same with mce-4000
-take a aluminium pipe 8mm diameter 30cm long
-push it over the microphone cable
-solder the cable to the capsule and to a 3,5mm mono jack plug
-tape the capsule to the pipe, I used electrical tape, and tape the cable at the other end making some sort of pull relief
microphone ready!
Frequency response was flat far beyond 10kHz.
regards
Old 2nd May 2007, 12:43 PM   #4
Many thanks for the response - it's just that I understood these things needed a phantom power supply, and a pre-amp?
Old 2nd May 2007, 01:42 PM   #5
if you want line level output yes
or do you want to use the mic input of a computer?
it has build in phantom power and preamp
the simple microphone could be attached directly to it
regards
Old 2nd May 2007, 03:41 PM   #6
Unfortunately, it needs to go into the line in input on a PC, so does need to be at line level.
I was looking at a Behringer ECM8000 mic (about 35GBP). Once you add the cost of a pre-amp and power supply, and the XLR cable, it's nearer 100GBP!
Old 17th July 2007, 12:05 AM   #7
made a few pics
total:
Old 17th July 2007, 12:08 AM   #8
head:
Old 17th July 2007, 12:11 AM   #9
capsule:
Old 17th July 2007, 12:18 AM   #10
watching my own pictures, I now see a stereo connector.
sorry!
Threshold 4000 R-K Rønningstad Pass Labs 10 28th August 2009 05:27 AM
Monacor MCE-4000 Alcaid Multi-Way 9 19th January 2005 12:50 PM
Page generated in 0.12198 seconds (72.76% PHP - 27.24% MySQL) with 11 queries
