Old 2nd April 2007, 01:45 PM   #1
Default Speaker isolation
I'm building some in 3way speakers to be fitted behind a false wall. I presume I shouldn't fix the front of the speaker cabinet to the false wall? If not, how should I go about isolating speakers from walls? Same will apply for 2 way speakers built into bulkheads (soffits)??
Craig
Craig
Old 2nd April 2007, 10:43 PM   #2
Foxx510 is offline Foxx510  Australia
Can you mount the grill to the wall, and then sit the speaker behind that mounted to the wallframe?
USB DAC isolation ? soundcheck Digital Line Level 85 5th May 2012 06:00 PM
PS/Amp isolation in 1 box ? jimbo1968 Chip Amps 5 20th May 2005 07:04 PM
Isolation eeka chu Tubes / Valves 4 6th December 2004 06:53 PM
isolation pad rulezzz Solid State 0 10th January 2004 05:25 PM
about isolation rulezzz Chip Amps 1 8th January 2004 05:36 PM
Page generated in 0.06374 seconds (64.49% PHP - 35.51% MySQL) with 10 queries
