Old 1st April 2007, 01:32 PM   #1
Unhappy Acoustic Energy AE1
one of my AE1s has gone kaput.
The mid/bass voice coil is rubbing, well more accurate to say, almost locked solid.
It must have overheated and on cooling became distorted.
Does anyone know of a replacement driver that fits the cornered rebate and is a good substitute for the T/S parameters of the original?
The last time I replaced a driver, Acoustic Energy took £75 off me for an exchange unit and that was about 12years ago. I don't even want to ask their price for one now.
regards Andrew T.
Old 1st April 2007, 02:09 PM   #2
pinkmouse's Avatar
Are they the little plastic ones? I have a pair that have been sitting around in the loft for ages, redundant to needs, and I'll sell you the pair for £75 + postage
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st April 2007, 02:24 PM   #3
the AE1s are fitted with a 130mm pressed steel basket, aluminium cone and centre cap, rubber half roll surround, 134mm PCD mountings.
They have an aluminium voice coil former (it may be in one piece with the centre cap) about 30mm diam and supposedly 150W power handling through the passive crossover.
regards Andrew T.
Old 1st April 2007, 02:31 PM   #4
kvholio is offline kvholio  Netherlands
kvholio's Avatar
awww i feel your pain Andrew.
Are they these ?
http://www.stereophile.com/standloud...526/index.html
From what i know these have a cast metal chassis, foam surround .
edit: i see there were several versions, yours might be different.
Using something else will essentially mean you're ditching the original designs , these are true little marvels.
Auditioned them against my ae-509's , except for the low-end extension they were better in all other areas.
With kind regards,
Klaas
Old 1st April 2007, 06:40 PM   #5
Hi Kv,
not the rosewood, just the cheaper black ones , Mk1 from 1990.
I do keep things a while.
The Tannoys they replaced have just had new surrounds and will soon be back performing in stereo.
The AE1s are for surround sound and a missing corner speaker will kind of unbalance the effect!
regards Andrew T.
Old 1st April 2007, 07:19 PM   #6
kvholio's Avatar
Yeah me too, have the ae-509's for about ten years now, still happy with them.
If the ones Pinkmouse is referring to aren't what you are looking for, you could have a look at Monacor. They might have something that fits and provide good build-quality for the money.
=> http://www.monacor.de
With kind regards,
Klaas
Old 2nd April 2007, 11:52 AM   #7
Hmmm...... extremely inaccurate comment.
The original AE1s are full range standmounters, and use a complex
crossover (5th ? order acoustic) at a relatively low crossover point.
Substituting an alternative bass driver is a non-starter.
Redesigning completely with the original cabinets and
tweeters is a possibility, i.e. new bass drivers and crossover.
/sreten.
Old 2nd April 2007, 11:59 AM   #8
Hi Sreten,
yes, I realise that a poor match will ruin the speaker.
That's why I am looking for a good match of T/S parameters.
It's just possible someone has done this before.
What was inaccurate about the comment? Four speakers spread around the four quadrants and then removing one! Agh, don't bother with an answer.
regards Andrew T.
Old 2nd April 2007, 12:18 PM   #9
kvholio's Avatar
Getting 2 decent-quality woofers and new cross-overs will easily cost you more than 75 pounds.
If they're built like my 509's the entire crossover is in epoxy-resin, so you won't be able to use a single existing part of the lf cross-overs.
With kind regards,
Klaas
Old 2nd April 2007, 12:35 PM   #10
Sorry I misunderstood the comment, its about your use, not the
intended use of the louspeaker. Well the original AE1 has now
been reintroduced as the AE1 "classic" with allegedly indentical
drivers - so a replacement might not be too bad.
FWIW fitting another unit to a pair - giving you a spare AE driver
for one pair is the other option I'd consider, but the driver needs
to be relatively inefficient. Frame size is 135mm ?
/sreten.
Acoustic energy aegis one quan Multi-Way 1 23rd December 2007 09:56 AM
Acoustic Energy Aegis Ones - T&S data? Gary Lightfoot Multi-Way 0 11th October 2004 05:37 PM
Acoustic Energy AE3 Reference marijan Swap Meet 0 27th April 2004 09:06 AM
Page generated in 0.10306 seconds (83.44% PHP - 16.56% MySQL) with 11 queries
