Old 31st March 2007, 04:35 AM   #1
Default My 2 way design... need xover help
My design is:
D26NC-55-06 tweeter
Seas CA12RCY woofer... 2 of them bipole config. run full range.
1st order on tweeter.
trying to figure out best x-over point of tweeter and if either tweeter or woofer need any compensation circuits.
so what x-over point shall i use and what value of capacitor??
finally, can i push these woofers to achieve a -3db of 58hz in a 0.32 cuft (for 2 woofers) tuned to 53hz?
or a flatter tuning of -3db of 73hz in a 0.2 cuft tuned to 75hz?
i can put both a port and a woofer on front and back. tweeter just on front.
I could even make the tweeter an external tweeter in a small enclosure so that it can be pointed the correct direction and also to time align the system.
Thanks!!!
It is not you... you are it.
Old 1st April 2007, 01:25 AM   #2
Rounder is offline Rounder  Canada
Hey,
based on graphs at zaphaudio.com i would say a crossover point between 2.3 and 2.5khz is reasonable for the tweeter and woofer. Most others will probably say that first order isnt steep enough, i personally have tried and compared and think that first order in enough to be safe and sound good, not to mention the simplicity. As for the two woofers, i think u would be ok to push for 58hz as long as u dont feel like giving ur speakers 200 watts or DJ duties. A zobel for the woofers would probably be a good bet to flatten the rising impedance. The driver configuration is up to u, i would keep it simple, mtm on the front and port on the back but it depends on ur needs. I havent seen accurate FR graphs for the woofer so i cant advise on notch filters. You should be able to figure out cpacitor values online with the frequency and impedance...
Good Luck
The bitterness of poor quality is remembered long after the sweetness of low prices is forgotten.
Old 1st April 2007, 04:08 AM   #3
Default i was thinking
i was actually thinking of running the woofer fullrange and just filter the tweeter with a cap.
woofer on back so that i do not need a BSC circuit.
the woofers are pretty flat to 10khz.
Old 1st April 2007, 06:04 AM   #4
Bose(o) is offline Bose(o)  Canada
Personally, I think you should look into getting that first order cross over. I find that speakers using some type of filter or control on a driver imparts a cleaner sound-one without the breakup modes of the loudspeaker.
You can always use a bypass cap as well, these seems to increase the minimalism of the circuit.
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 2nd April 2007, 02:28 PM   #5
Default well..
i was thinking of running the woofer full-range... so, need to figure out a x-over point to account for this.
its -3db down at 10Khz or there abouts.
worried about off axis suckouts though as the 30 and 60 degree drops of before 10Khz.
and i like the bipole configuration to get rid of the BSC circuit and its reduction in efficiency.
plus that woofer has a good xmax for its size and a low fs.
Thanks!
dual atc mid xover design mclsound Multi-Way 12 29th July 2009 01:56 AM
Proprietary Xover design? auriches Multi-Way 4 12th January 2009 10:10 PM
Xover design help Kram Multi-Way 38 5th January 2003 09:33 PM
Series xover design ronjg Multi-Way 26 4th September 2002 08:25 AM
Page generated in 0.09033 seconds (74.49% PHP - 25.51% MySQL) with 10 queries
