Old 30th March 2007, 05:58 PM   #1
sdclc126's Avatar
Default New Project at PE - The "Encore"
http://www.partsexpress.com/projects...core/index.cfm
I'm soliciting opinions on the crossover design for this project. I'm building a TM with a similar sized cab but with the 27TBFC/G. I've seen a bunch of different designs out there (like for the Modula and the several options listed at RJB Audio) - some of them very complex and expensive, to deal with the woofer break-ups etc. I've gotten very confused as to what to do.
Main questions about this design are:
1) Is the crossover point (2300) too high relative to woofer
break-up, and
2) Regardless of XO point, has enough thought gone into this in
terms of slope, notching, etc? Again the main issue here is
woofer break-up.
Thanks for all feedback.
Soft Dome
Old 30th March 2007, 11:47 PM   #2
owdi is offline owdi  United States
owdi's Avatar
1. I would have aimed for half an octave lower, around 1800hz.
2. I think so.
I don't know how well you could adapt that crossover to work with the Seas 27TBFC/G. It is a very different tweeter from the RS28AS. A 2nd order electrical network could do the trick.
Dan
Old 31st March 2007, 12:13 AM   #3
sdclc126's Avatar
Hey thanks for the reply.
Yes a below-2k XO point seems to be most common with metal drivers, so maybe I'll recalculate it to there.
And I should have pointed out that I'm aware that the SEAS tweeter is different from the Dayton and would not use the same hi-pass network for it - but do you think 2nd order is OK at 1800? Will there be a steeper acoustical slope, and how is that figured out anyway?
P.S. - I have no XO software - I can just do basic calculations.
Soft Dome
Old 31st March 2007, 06:29 AM   #4
owdi's Avatar
Do you have Excel? If so, you can use the FRD Consortium tools to model the speaker.
http://www.pvconsultants.com/audio/frdgroup.htm
If you don't have a way to measure your project, I highly recommend against designing your own crossover. I'm designing my third one, and it's not getting any easier.
Dan
Old 31st March 2007, 03:17 PM   #5
sdclc126's Avatar
Yes I have Excel and I suppose I should download some of these programs.
But I'm not intending to design my own XO - just trying to find an existing one that could be adapted to the 27TB without huge changes. They're out there, but the ones I've seen, even those specifically for the SEAS tweet, are either very complex/expensive or just not well reviewed here.
The search continues...
Soft Dome
Old 31st March 2007, 08:27 PM   #6
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
The search continues... [/B]
RJB Audio's Microbe SE Project
Is this close enough?
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
"Proac 2.5 clone" or "Elsinore project" Joel Wesseling Multi-Way 10 26th May 2011 05:51 AM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
My latest project - fantastic power amp "Sigma" Renx Solid State 30 3rd September 2008 06:49 PM
Suggestions on a preamplifier project with a "A/V processor loop" option Spyhunter Solid State 6 8th November 2001 09:31 AM
Page generated in 0.10365 seconds (74.66% PHP - 25.34% MySQL) with 10 queries
