Old 29th March 2007, 02:20 AM   #1
Audist is offline Audist  United States
Default measurement on LspLAB
Hi guy's.
I make a Near field measurement for the woofer and the tweeter with my first order crossover.
I use with a Calculator for merge a curves.
But I have some problem with the measurement...
If I use with "Average Curves" calculator and select Complex operation, I have some problem in 2140Hz. maybe is where the crossover is cut between the woofer and the tweeter... But if I remove the "V" from the "Complex operation" box, The graph look much better!
Anybody can tell me what is a truth graph?
Thanks for help.
Graph 1: with "Complex operation"
Old 29th March 2007, 02:23 AM   #2
uncheck the "Complex operation"
Old 29th March 2007, 09:38 PM   #3
opp is offline opp  Denmark
opp's Avatar
I'm not familiar with lspLAB, but my guess is that complex means, including phase - the orange curve in "graph1" indicates this. If I'm correct, then don't uncheck "complex operation", the phase information is important. E.g. read the Speaker Workshop manual 2.0 http://www.claudionegro.com/download.html - i know, it's a different software, but there is a lot of general speaker measurement theory.
time flies like an arrow ... and fruit flies like a banana
Old 31st March 2007, 06:56 PM   #4
Svante is offline Svante  Sweden
Svante's Avatar
I am not familiar with the software either, but indeed it seems like the "complex" option uses the phase of the signals when making the combined curve, just as in real life.
Both the name on the tick box and what happens indicates that this is the case.
If this is right, I cannot imagine a reason for not having it checked. In fact, I think the checkbox should not be there. The only function it has is to show that the program can do proper (complex) addition of the curves, and to demonstrate how bad (=nonrealistic) it is not to have it.
But maybe I fail to see a good reason right now. Anyone?
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 31st March 2007, 07:07 PM   #5
hello,
range : -80 up to 20dB ? 100dB in your curve then we can see nothing ...
Old 31st March 2007, 07:50 PM   #6
opp's Avatar
Hi
Just to get this right.
All this about check, don't uncheck etc. is a little confusing - phase information is mandatory in speaker design, therefore Graph 1 must be correct.
4lexander - IMO 100 dB gives a good overview, you can always zoom in.
Old 31st March 2007, 08:05 PM   #7
Hello,
But, any speaker will be like linear with 100dB range...
just my remark ...
Old 31st March 2007, 08:40 PM   #8
opp's Avatar
Originally posted by 4lexander
Hello,
just my remark ...
4lexander
Agree - but the resolution of graphs posted by Audist is almost 1dB. Personally I always zoom in on xo points etc, but also use the 100 dB view.
LspLAB 3.01 - impedance? Audist Multi-Way 4 1st March 2008 02:43 AM
WM-61A + LSPLab, why so bad? Heelp! kimschips Multi-Way 6 28th July 2006 09:31 PM
New measurement mic in UK pinkmouse Multi-Way 4 10th February 2005 05:46 AM
LSPLAB 2.20 - measurement box v3 lmic Multi-Way 0 18th February 2004 05:18 PM
Page generated in 0.09276 seconds (74.15% PHP - 25.85% MySQL) with 11 queries
