Old 27th March 2007, 12:24 PM   #1
Default EA: How So Small With Extended Low End
Hi everyone!
There's something which has been puzzling me for many years. Euphonic Audio make bass guitar amplifiers and speaker cabs. Their cabs are transmission line designs which are small, efficient and produce deep, extended bass (I once had a shot of their 1x10" coaxial bass combo and can attest to their bass extension).
http://www.eaamps.com/2005/products/cxl112l.htm
For example, here are some of the specs for the CXL112:
19"H x 17"W x 15"D
103dB @ 1m
38Hz to 14kHz
My question is; how do they do it? I'm not sure if the fact that they use TLs helps explain this or make it even more inconceivable. Anyone up for discussing this?
If it ain't broke, break it.
Old 27th March 2007, 02:26 PM   #2
Hmmm........
Transmission line cabinets can be designed to have a smoother and more extended low
frequency output than a corresponding vented enclosure given the same internal volume.
Only true if the box is too big for proper vented in the first place......
/sreten.
Old 27th March 2007, 02:52 PM   #3
Wow!....
Did I miss a post? Where did that quote come from Sreten?
Old 27th March 2007, 04:15 PM   #4
pinkmouse's Avatar
They are probably tuned to about 60-80Hz, to give you that "punch in the chest" feeling, rather than real low extension.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 27th March 2007, 04:38 PM   #5
Hi Pinkmouse.
I have to say that I really don't think that's it. I played my bass through the 1x10" combo with a 1x10" extension cab attached and it sounded way deeper and more solid than (probably) any other cab I'd ever heard. Certainly more so than my previous amp witch had a 15" driver tuned to 40Hz. It wasn't boomy in the slightest.
Old 27th March 2007, 06:15 PM   #6
Originally posted by Depth Charge
Wow!....
http://www.eaamps.com/2005/technolog...ssion_line.htm
/sreten.
Old 27th March 2007, 06:45 PM   #7
Ah....of course. You've got to love the guy with the beard!
Now maybe I got the wrong end of the stick, but I was always under the impression that once you started using 8" and 10" drivers and beyond for your transmission lines, the cabinets started to get really really big and that was true for low efficiency hi-fi drivers as well as pro drivers. If that's true, how do they make them so small?
Maybe I should just buy one, measure it and take it apart to see how it's made. Although it would defeat the purpose of figuring out how they're made so that I can make something similar but cheaper because I can't afford their products in the first place.....
Old 27th March 2007, 07:13 PM   #8
You cannot break the laws of physics in an enclosure.
19"H x 17"W x 15"D.......... large for a 1x12" cabinet
103dB @ 1m...................... yeah right......
38Hz to 14kHz................... possibly
/sreten.
Old 27th March 2007, 08:49 PM   #9
frugal-phile(tm)
planet10's Avatar
That box is almost for sure an aperiodic box, with a partition in it to create a short heavily tapered line... anyone seen a picture of the back?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th March 2007, 09:13 PM   #10
Hey Dave,
If you're talking about the back of the CXL112, no I haven't. There is a 'vent' at the bottom on the front and I'm reasonably sure that the back just has the connection terminals and L-pad and nothing else.
I'm interested that you think it may be an aperiodic enclosure, mostly because I know so little about them. Can they be modeled in Martin King's Mathcad sheets by increasing the stuffing density and so fourth?
Steve.
Extended range measurement mics and pre-amps percy Multi-Way 1 17th November 2007 01:55 AM
Extended range tweeters and headphones percy Multi-Way 0 17th November 2007 12:04 AM
What is meant by 'Extended Cut-off'? Alastair E Tubes / Valves 5 5th May 2005 02:18 PM
What to do with these OLD 10" extended range drivers? swirv Multi-Way 9 23rd July 2004 07:27 PM
Page generated in 0.10374 seconds (80.07% PHP - 19.93% MySQL) with 10 queries
