Which is the better response curve here....
Old 21st March 2007, 06:49 AM   #1
Foxx510 is offline Foxx510  Australia
Default Which is the better response curve here....
Another newbie question. I'm making new enclosures for my 4412a speakers, just wondering which is the more desirable response curve for the 128h woofer. I'm guessing the first one, although the second one goes a bit lower. Any help much appreciated.
This
or this
Old 21st March 2007, 06:58 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
In most rooms the 2nd one... you might want even a bit more droop. It also depends where in the room you are going to put them.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st March 2007, 07:07 AM   #3
Interesting, and thanks for the quick response. So I should tune it even lower? I can't get much more droop really without tuning really low even if I up the volume.
Thanks,
Adam
Old 21st March 2007, 07:23 AM   #4
frugal-phile(tm)
planet10's Avatar
What you want to do is try to match the droop with your room gain so that you end up with flat response.
dave
Old 21st March 2007, 07:39 AM   #5
Ah ok. Given that I live in rental accommodation I guess I will have to comprimise on an "average" room response. I'll go with something along the lines of the second response curve.
Thanks.
Adam
Old 21st March 2007, 10:12 AM   #6
R.I.P.
FWIW I like to drop the tuning until there is no obvious "knee" point.
That is the droop rate accelerates as you go down, good general matching.
This is usually Fvent around 0.7 of normal (half an octave) and in my
experience you do get the sound of half an octave of extra bass,
given the rest of the bass is more controlled and better damped.
Often the - 6dB points are very near, -10dB is always better.
For the above I'd probably go for 26 Hz to 28Hz.
/sreten.
Old 21st March 2007, 10:46 AM   #7
Thanks sreten. I'll give 80liters at 26hz a try to start with. I guess I can always tune the port later if I want to experiment. I'll be back with more questions at a later date when it comes to the baffle layout.
Adam
Which is the better response curve here....Hide this!Advertise here!
Produce frequency response curve REALFLEO Multi-Way 1 7th February 2007 02:34 PM
what does the response curve of a bass guitar speaker cab look like? Optical Instruments and Amps 11 2nd May 2005 12:11 PM
When making a response curve... Howard Subwoofers 8 8th November 2004 07:36 PM
Vifa, extra lines in response curve graph? Layberinthius Multi-Way 3 31st March 2004 10:48 AM
What's a good response curve amoeba86 Multi-Way 29 18th July 2003 11:53 AM
