Old 21st March 2007, 02:34 AM   #1
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
Question new Hi-Vi surplus drivers 3"
I just found these 2 3" drivers and was wondering if anybody has used them or has information on their frequency response beyond parts express's info.
I did not find them on Hi-Vi's site(only the A2S is listed in this series) and google turns up little info.
HI-VI A3N SHIELDED ALUMINUM DRIVER PAIR
HI-VI A3SII SHIELDED ALUMINUM DRIVER PAIR
this mobile thread mentions them.
Old 22nd March 2007, 08:46 AM   #2
frugal-phile(tm)
planet10's Avatar
The less expensive ones look particularily interesting...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd March 2007, 10:34 AM   #3
adason is offline adason  United States
adason's Avatar
they both are patheticaly unefficient
i have not hear these particular ones, but my experience in general is that i do not like unefficient drivers
somehow they sound without life
Old 22nd March 2007, 05:30 PM   #4
frugal-phile(tm)
planet10's Avatar
I tend to agree with you ,,,, the problem with small drivers is that efficiency has cone area in the equation so the smaller the driver, the less likely it is to be efficient. And if that driver has lower Fs its efficiency goes down even further,
The efficiency of these is trypical of the class, the Fostex FE8x drivers probably being the most efficient.
dave
Old 23rd March 2007, 01:30 AM   #5
lodger_001's Avatar
check the pe message board, theres a post that has frequency response and impedance for the a3n. unfortunately none for the a3sii atm
Old 23rd March 2007, 03:57 AM   #6
I find at close to 85 db they are pretty typical spl, more than loud enough for a mid size room, if your families health is important and you dont want them to go deaf over the next few years, a wise choice.
Old 23rd March 2007, 04:04 AM   #7
Mikett is offline Mikett  Canada
A Line Array is one way to combat the inefficiency and these may well be suited to that purpose.
Old 23rd March 2007, 04:21 AM   #8
frugal-phile(tm)
planet10's Avatar
In my room, with my favorite amps having less than 5W, the 91/92 dB speakers i use are right at the edge of being efficient enuff.
dave
Old 23rd March 2007, 04:26 AM   #9
frugal-phile(tm)
planet10's Avatar
Line arrarys have facinated me since i was a teen. But every time i do the math getting a single, better driver just seems to make more sense.
The fact that the line arrays i have heard -- with the exception of my acoustat 1+1s -- have not been very impressive hasn't helped at all either.
dave
Old 23rd March 2007, 04:41 AM   #10
I was fortunate enough to get the spec sheets from Chris F at parts express.
The A3N driver actually suites my needs better.
I was looking for 100-150Hz in a 3" to above 4K hz
I already own the Tang Band W3 593S 3" driver 264-809. These are a 3 way design on my pc using a pair of surplus 5.25"and will likely keep the same Dayton ND20FA-6 275-030 tweeters. I am tri amped so sensitivity is not of much concern.
I also wanted something easy enough to reference to the common Hi-Vi B3S and B3N.
70cm tall, 3 way, diy speakers based on 10"/4"/1" japanese ken brown drivers. facundonu Multi-Way 34 9th March 2009 04:59 AM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. Spasticteapot Swap Meet 1 5th November 2006 03:31 PM
Ported Enclosure using Surplus Vifa Drivers wrenchone Multi-Way 15 5th April 2004 03:19 PM
Page generated in 0.10561 seconds (81.36% PHP - 18.64% MySQL) with 10 queries
