Old 20th March 2007, 11:28 AM   #1
irb is offline irb  Scotland
Default Protecting tweeters while testing
When measuring the frequency response of a tweeter with a computer based measuring system, (e.g. Soundeasy, LSPCad) what is advisable in terms of tweeter protection?
Ian
Old 20th March 2007, 11:49 AM   #2
Did it Himself
richie00boy's Avatar
Run at quiet levels and include an active high-pass filter. Then you add the filter response to the measured response to end up with the overall curve. Obviously this will only be good for maybe 20dB down the filter slope, but that should be more than far enough to investigate.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 20th March 2007, 08:06 PM   #3
dlr is offline dlr  United States
Default Re: Protecting tweeters while testing
Ian
If you are measuring in 2-channel mode (recommended) and using an MLS test signal, you have two options. You can measure at low levels with no protection. That's all I've ever done, but you do run the risk of tweeter damage if there's a problem or if you over-drive the tweeter. Higher power levels can be useful because that improves the S/N ratio.
The other method is to use a series cap, though I've never done this myself. If you use a cap, all you need to do is ensure that the probe is connected after the cap, that is, on the tweeter input lead. The probe eliminates all upstream influence, preamp, power amp, capacitor, conductors, etc. There's no need to include the cap in any model. This will also let you more safely increase the power level. There will still be some decreased S/N in the rolloff area from the cap, but at least it's still protected. It's also not usually that much of an issue with tweeter SPL measurements.
Old 22nd March 2007, 09:16 PM   #4
Thanks to both of you! This is very helpful.
Ian
Simple DIYable Waveguide testing (dome tweeters) dlneubec Multi-Way 3 14th October 2008 04:10 PM
why is my amp protecting? mbugua Class D 2 19th January 2007 12:58 PM
protecting mosfets in UcD zilog Class D 10 12th November 2006 07:52 PM
FS Accuton C2-22 tweeters, pair, used for 5 mins of testing Mark Hathaway Swap Meet 0 1st March 2004 03:26 AM
protecting my speakers from my GC damitamit Chip Amps 13 16th June 2003 03:46 PM
Page generated in 0.08367 seconds (72.64% PHP - 27.36% MySQL) with 10 queries
