Trying to decide on a cabinet for a pair of TAD tl-1102 I just purchased.
Has anyone modeled these drivers in the petite-onken cabinet? What would the advantage of the onken cabinet be over a conventional ported bass reflex enclosure? Any idea on a modified onken that would be better (and maybe a little smaller?) Opinions on the ideal enclosure for the tl-1102's? Putting them under a pair of td-2001s crossing over around 1600hz on 800hz horns. Plan to build in the next few weeks would really appreciate your input. Will document this project here. Thanks! tl-1102 |
#2 |
Hi, thats a dream driver, for sure - but how will you mate a 94db woofer with a 109db compression driver
I would be looking at something around 90db to match it GM, I think is the expert with Onken something about making it 6-7 times as big .... as big as what ? Which MAYBE would mean 300-350 liter - lets see if GM has the time correct this |
#3 |
Yea, I remember that GM has all the specs on the Oken cab. and ran some great plots for some other drivers i was looking at.
Hope he reads this post. As far as efficiency. the td-1102 should still be good for about 92-93 db .. I know that Duke at AudiKinesis has been using them, sent me his measurements and they are really close to spec. and are flat from mid 30' to about 1600. Also the Tad Monitors used this combination of the 2001 (the 2002 actually) and the td-1102 and were 92db efficient or something.... Anyhow.. the dispersion characteristics of the 11" driver make it seem perfect for the 2001 yes.. a shame to have to pad them down so much to match the horns.. if i got two more drivers and put them in the onken.. hmm.. .. they would hardly be petite.. wouldn't they need to double in size? hubba hubba. |
#4 |
You could use a tweeter amp with little lower gain
#5 |
exactly! Bi Amping would be easy huh. I have a Red Wine Sig 30.. which has attenuated RCA outs.. i could use a second amp for the horns and let the sig 30 run the mid/bass...
gotta settle on an enclosure before i start going there though. i liked the idea of the petite onkens because i was thinking if i liked them and wanted to make a prettier pair or if i didnt like them i could use the first cabinets with some altecs for a garage speaker or something... anyhow... maybe i should just stick with a normal bass reflex.. thats everyone seems to have used to date with these drivers.. was curious if the onkens would work though and what the advantages would be with them... |
#6 |
The td-1102 doesn't look promising in an Onken enclosure I'm sorry to say, vent length is almost double the max allowable. You can try the excel calculator for yourself just to make sure:
http://melhuish.org/audio/software.html Use Mms = 41 to get the correct Vas. Try this driver in WinISD for a standard BR. Jeff |
#7 |
ah.. thanks for the calculator link. looks like id better stay with standard reflex box for these...
#8 |
Greets!
The Petite Onken is way too big, though with two drivers it sims like the big Altec 416 Onken GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 | |
Not sure what you're referring to. I mean how much it gets over-sized from a n = 6.34 alignment with just its T/S specs is a function of how much series resistance there is and/or how low tuned/rolled off you want it so it will blend to the room's gain curve. GM
#10 |
Hello ark,
Have you listened the TAD driver yet? I hope you managed to find an enclosure for it... |
| Wtb:Tad TL-1102, Td-4003, Et-703 | matsj | Swap Meet | 2 | 24th April 2008 01:01 PM |
| Tad Tl-1102 | David Gatti | Multi-Way | 18 | 14th June 2007 11:26 AM |
| Petite Onken Quandry | hatfield | Multi-Way | 8 | 15th November 2006 04:46 PM |
| TAD TL-1102 question | amo | Multi-Way | 8 | 17th May 2004 06:13 PM |
| l'audiophile PETITE | lohk | Multi-Way | 11 | 1st February 2002 12:59 PM |
| Page generated in 0.10403 seconds (78.95% PHP - 21.05% MySQL) with 10 queries |
