Hi
(this a spin off from Horses for courses - Optimal boxes for different passbands) There seem to be two approaches to Constrained Layer Construction: Wilson Audio say the best form of CLD is twin identical panels of the same mass and stiffness. Like two sheets of equal thickness MDF or Plywood. Then the glue between the sheets has to remain soft and plyable but not too thick More in post 12 here Horses for courses - Optimal boxes for different passbands Whereas a local who’s been DIYing for 30 years, uses a composite of 2 - 6! bonded layers “which have different thicknesses, materials, densities and therefore resonant behavior. A single layer cannot vibrate at its particular resonant frequency because it is so heavily damped by the other layers. . . “Good materials I’ve used for constructing composite box walls are: 1. Chipboard flooring (yellow & red tongue) - it has 3 pronounced layers of differing densities, and it’s fairly cheap 2. Plywood (at least 18 mm thick, and with plys at least 3 mm thick). Small air voids would make no difference. Expensive. 3. Masonite (a low density thin layer which helps to break up resonances). Cheap.- Ordinary chipboard. Cheap 4. 5 mm bitumen impregnated vinyl (used for deadening sound transfer through panels in cars etc). Can use 1, 2 or 3 layers stuck together. 5. Sand and bitumen paint mixed to make a render. Very messy, smelly and takes a long time to dry. http://groups.yahoo.com/group/maclub/message/26753 His latest evolution was 1. 1 mm Walnut wood veneer, 2. 4.8 mm Masonite, 3. 2 layers of 3 mm car sound deadening panels, 4. 19.5 mm "yellow tongue structafloor" chipboard, 5. 1 layer of Bostic (car sound) deadening panel, 6. 14 mm poly foam. (he uses a contact adhesive, and small zinc plated nails to hold on bitumen or lead panels while the glue dries) with modest drivers, sounded Very good Tho I'd only do 6 layers for an "Ultimate" project The logic of “different thicknesses, materials, densities and therefore resonant behavior, and A single layer cannot vibrate at its particular resonant frequency because it is so heavily damped by the other layers.” - to me sounds more convincing . Any other approaches or views? Cheers |
#2 |
diyAudio Moderator Emeritus
Rick,
For CLD to work properly, there needs to be an elastic damping layer sandwiched (bonded) between two more ridgid layers. At certain frequencies the two outer layers will be de-coupled from each other and will vibrate and be damped independently according to their separate properties. At these frequencies, the elastic layer does not pass the vibrational energy from one outer layer to the other. The three layers acts as a lowpass filter so at lower frequencies and all three layers will vibrate together. The cutoff of this filter should be low enough to be below audible range or be damped enough to minimize excessive vibration. However, at certian frequencies, the outer layer masses will resonate against the spring of the elastic layer. This would a good reason for selecting two outer layers with different properties. The outer layers should be selected with the stiffness, mass, and internal damping to resist vibrating at these resonant frequencies. Selecting the correct materials and construction for proper CLD methods is not trival and will require some advanced analysis or a lot of experimentation, or both. To complicate matters significantly, more layers can be added including the addition of Free Layer Damping (coatings) methods and different panel geometry.
Rodd Yamashita |
#3 |
Personally, I would build two test boxes. Both very cheap.
1. yellow tongue chipbord- silicone bathroom sealer-yellow tongue chipboard. I can imagine the resonance of both inner and outer panels to be around equal, and with the silicone acting as a compliance material, the second outer board may (or may not) resonate in anti phase with the inner wall, cancelling overall resonance to some degree, and at some frequencies. Gotta be worth a test box! 2. Masonite-siliconed to an open timber frame- siliconed to masonite, voids filled with sand. Energy travelling through the inner masonite panel would be absorbed by the loose sand before reaching the outer skin. Any energy transmitted through the silicone bond into the timber frame would need to travel through another silicone bond before transfer to the outer skin. the frame could even be made from chipboard with slots or holes cut into it. Mind you, there is a good chance neither would work in practice, but it would be a nice and fairly cheap study if I had the time! |
#4 | |
The definition of CLD is two panels separated by a thin viscous layer. I asked him why they needed to be equal and he gave me this answer, if you have a rigid substrate and constraining layer (i.e. thick wood) then when one is set into a vibratory mode it will only resonate at higher frequencies due to its stiffness, high frequency resonance causes smaller ripples when compared to low frequency resonance. This ripple causes "shear strain" in the damping layer, which is converted into low level latent heat, instead of transmitting or reflecting it. The problem with thin constraining layers is that they don't resist low frequency modes which when taken in the context of a composite structure, the low freq. modes appear as thin panels bending towards the thicker panels, the thin damping layer cannot convert this compression strain into heat as efficiently so it transmits it to the next layer. It will still work, but efficiency is lost. The important thing is to have a constraining layer, free layers are not any where near as efficient. Not the most descriptive or technical answer but... for more info:CLD |
#5 |
That PDF shows that the thinnest damping layer is the most effective at room temperature.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#6 |
Ok, that is the damping layer, we are talking about the constraining layer and the substrate thickness.
Also, they only tested at one frequency, so we can't accurately judge broadband performance from this pdf. |
#7 |
Ah, I confused "constraining" with "damping". My mistake.
#8 |
[QUOTE]Originally posted by rick57
[B]Hi His latest evolution was 1. 1 mm Walnut wood veneer, 2. 4.8 mm Masonite, 3. 2 layers of 3 mm car sound deadening panels, 4. 19.5 mm "yellow tongue structafloor" chipboard, 5. 1 layer of Bostic (car sound) deadening panel, 6. 14 mm poly foam. (he uses a contact adhesive, and small zinc plated nails to hold on bitumen or lead panels while the glue dries) with modest drivers, sounded Very good Rick57: Sounds like he is trying to contain the Devil himself... I have used chipfoam underpad between an inside box and an outer box, the only physical conection between them was at the bass driver. Worked beautifully. |
#9 |
Hi Rick,
i have previously used silicone and a water based contact cement for CLD panels and been underwhelmed with the results. I've just used Green Gluehttp://www.greengluecompany.com to make an open baffle speaker with 15mm birch ply and 12mm viroc (a cement wood fibre board). I also used it to quieten some portable humidifying machines at work. I am very pleased with the results the green glue does seem to be the right stuff to use. If you can get hold of it in oz I would definitely use it, i's primary use is for applying between plasterboard for sound proofing but it works just as well with wood. The things to note is that you have to use screws or nails to join the panels. I used a few 18Ga brads from a nail gun, also make sure you find something to clean it up before you start, it flows quite easily when first applied but then remains permanently tacky. I used a citrus based glue remover. If I ever make any more boxes I would definitely use it. regards Khush |
#10 |
Richard,
Tony Gee used a 3-layer approach to both boxes for his Andromeda speakers. 22mm MDF, then 4mm lead-bitumen, then 18mm MDF. Worth a read. But it's interesting to note that he hasn't gone back to this approach since, even for his Soup speakers. Possibly the extra work involved doesn't produce the improvement desired. You would have to ask him yourself - he is a member here "Geenius".
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
| Adhesive/materials for Constrained Layer Damping | Paul W | Multi-Way | 24 | 27th October 2008 04:35 AM |
| Constrained layer damping / thin metal / fibreglass layer | RobWells | Multi-Way | 3 | 6th August 2007 05:50 AM |
| how to mount drivers in cabinets with CLD (constrained layer damping) structure? | Spilferderber | Multi-Way | 15 | 15th November 2006 06:54 AM |
| Enclosure/constrained layer type question | Bill Fitzpatrick | Multi-Way | 3 | 29th November 2004 08:13 PM |
| Combining constrained layer damping and bracing | rick57 | Multi-Way | 9 | 29th November 2004 03:06 AM |
| Page generated in 0.14893 seconds (82.62% PHP - 17.38% MySQL) with 10 queries |
