i want to build some panels out of 2x6 and this stuff
http://roxul.com/sw34143.asp i'm not sure how large 1 can make the panels,but they can only be a maxmium of 6" thick.the room is a almost square loft apt.i will post a couple pics later.first i need to know it this would work and be worth while. |
#2 |
Speakerholic
It's what I like to use inside speakers so I would think it would work for room treatment. Are you planning to buy the compressed stuff or the looser batt type? I'm thinking the compressed stuff would be nice to work with.
EDIT: On closer inspection, I see that is the compressed stuff. |
#3 |
Something like this would be good for you http://www.aeronet.com.au/Aeropanel%20Absorber.htm
#4 |
Speakerholic
If you can afford the leather couch in the picture you can probably afford the aerogel panels.
#5 |
It is a nice looking room! But yeah, he shows how to make the panels so DIY!
You could use the compressed fibre instead of the foam he does, but I'd cover it with a fabric to stop it falling out and to look nicer through the gaps of the wood. |
#6 |
heres a pic of the front.1 could fit a 2'x10' panelbelow and above the screen.do you think this would helpi can get more pics of the place when i have better light.the couch is about middle of the room.the areo panel looks interesting.my main concern is the low end.
| Room treatments - diffusion & absorption... | darkmoebius | Everything Else | 0 | 20th July 2005 02:35 AM |
| 2" rigid high density fiberglass for acoustic room treatments? | darkmoebius | Everything Else | 6 | 6th May 2005 08:44 PM |
| C37 frequencies and treatments | mrfeedback | Everything Else | 0 | 8th April 2002 05:07 PM |
| Contact Treatments | mrfeedback | Everything Else | 0 | 18th March 2002 01:16 AM |
