I need real dimension for box to make sistem with
DYNAUDIO 21W54. Thanks ! Regards zeoN_Rider |
#2 |
A 1982 kit from Dynaudio states 60 litres with 2 variovents.
Seems too big for me. A 1984 publication says 40 litres bass reflex - port 15 cm long and 7.5 cm diameter. I am not sure whether the diameter is measured inside or outside. Also take into consideration Wilson WATT Puppy 6. There are 2 drivers in a bass reflex volume of approximately 50 litres. |
#3 |
diyAudio Chief Moderator
25 litres net, 7cm inner d tube x 25cm L
#4 |
Tell me how you calculate that dimension , it look very small.
#5 |
I have made some speaker once with that unit that I measured it on my own and I had some notes about the cabinet. It looks ok with the Wilson example though. But don't count on me as much because its been yrs and maybe the woofer had changed by the manufacturer? Better measure the units you have in hand.
| Dynaudio 24W-75 problem | diymax62 | Multi-Way | 0 | 30th December 2007 01:57 PM |
| Problem with small car amp | Dan2 | Chip Amps | 6 | 17th February 2007 04:33 AM |
| Small problem at power off | nilrog | Tubes / Valves | 8 | 8th June 2005 06:45 AM |
| Help with hum small hum problem... | Guiness | Tubes / Valves | 10 | 5th May 2003 04:23 PM |
| Page generated in 0.07559 seconds (69.03% PHP - 30.97% MySQL) with 10 queries |
