Hi All,
I've had a load of panels for 2 labhorns in my garage for the last year. Just been out there and the mdf has some mould along its edges. My garage is very dry usually, but I guess a combination of lots of rain outside and the coldness inside has done it. It was fine right up to a week ago. Is it just a case of bleaching the mould off and bringing the panels indoors to dry out, or is it all firewood ? I hope it's salvageable as they're meant to be being assembled for the UK diy meet up. Cheers, Rob. |
#2 |
A pic. Poor Q camera. Black edges are from laser burn when cutting.
The mould is the whitish stuff. |
#3 |
...truth seeker...
check the thickness with a piece you know is unaffected...look for swelling of the portions that were exposed...particularly those closest to the floor...move them into a location that is dry...if any of the material is suspect test further by installing a screw and trying to pull it out...hth...and good luck
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#4 |
Hi Ed,
There's no swelling that I can see. The stack is sitting on a low table about 1' off the floor. I'll bring it all indoors to dry off, although the garage isn't particularly damp usually. This is the 1st time anythings gone mouldy in there... I guess I'm worried if the mould spores will get into the mdf itself and cause any problems once the speaker is assembled and painted. Hopefully not. It's not the cost of replacing the mdf thats a problem, its the time I put in doing all the mitres etc. I really don't want to do it all again. Cheers, Rob. |
#5 |
Rob...
You might try spritzing with 5:1 diluted bleach to kill off the mold b4 drying... multiple bleach & dry maybe... just don't overwet the panels to keep them from swelling.... Sun exposure of the affected areas also will help (or a uv lamp if available) Good luck... John L.
"...His brain is squirming like a toad..." Jim Morrison |
#6 |
Hope they're OK Rob, really looking forward to hearing those come July.
The photo is a little hard to make out but Ed's advice sounds sensible to me. |
#7 | |
#8 |
If the pieces are not cut to size, trim the edges off with your table saw and see how deep the mold goes. The edges are most likely to have moisture penetrate so if they are trimmed I would say they are good to go, especially since there is no swelling in thickness.
#9 |
Thanks for the replies guys...
bigboy, They're all cut to size so can't trim no more. Rob. |
#10 |
Well just had a closer look today and some of the bits have developed fine cracks along the edges. Just put 2 whole labhorns, ready to assemble on a big fire in the garden.
Better get some more mdf in..... Rob. |
| Garage sale | Moondog55 | Multi-Way | 0 | 2nd October 2008 08:52 AM |
| Garage sale | JensRasmussen | Swap Meet | 20 | 11th July 2007 05:24 AM |
| Garage Sale | woody | Swap Meet | 6 | 16th November 2006 05:35 PM |
| garage speakers | regal | Multi-Way | 1 | 24th September 2004 02:28 PM |
| Garage sale | woody | Swap Meet | 1 | 16th October 2002 12:49 PM |
| Page generated in 0.10422 seconds (78.60% PHP - 21.40% MySQL) with 11 queries |
