I'm trying to find either a kit or plans for a somewhat efficient bookshelf, but so far I haven't had much luck. I am looking for around 87db/w/m. I would really appreciate any recomendations. Thanks.
Whit |
#2 |
1) How large is too large?
2) What kind of material do you listen to- do you need extremely low bass? 3) Do you listen at a high SPL? 4) What kind of amp will you use- solid state, or tube? Specifically, is it OK for 4 ohm loads? These are important questions for coming up with a good project. My bookshelf might be larger than your bookshelf, you know? Just guessing, but I think that something on the large side with a paper woofer is what's going to do it for you. I'll look around a bit if you don't mind answering my questions. |
#3 |
#4 |
Hi Joe,
1) I'd like them to be 14hx9wx13d or smaller if possible. 2) I mainly listen to jazz and classical so I don't need extremely low bass. 3) No, I like around 70-75db. 4) It will be a solid state class-D amp. 4 ohm loads are ok. |
#5 | |
frugal-phile(tm)
![]() 1st entry on the Fostex box-plan library page http://www.planet10-hifi.com/boxes-fostex.html I'm predudiced but think they really are stunning. I listen mostly to jazz with classical taking a big up-tick recently. These seem to work well with Class D amps. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
I still haven't purchased a small full-range driver to see what that's all about, although a lot of people like them. Still, I'm not sold on the idea.
According to models based on excursion, I have a fairly good idea of when my present speakers ought to start sounding horrible. Sure enough, if I feed them some loud bass they do start to freak out as predicted. With a small driver with low Xmax, I can't help but think that without some major horn loading there would be a major limitation in dynamics and bass. Give them bass bins and I might be on board. I do agree with the part about Class-D amps, though. This kind of driver has often been said to work best with tube amps. Tube amps have a higher output impedance than solid state, something they share in common with Class-D. With and classical, I kind of like the shallow roll-off of a sealed enclosure. Sure I'm not getting the deep notes, but the way the response tapers off sort of leaves them to my imagination and doesn't sound as unnatural as a ported box that's overdoes the bass. Extended bass shelf tunings sound nice to my ears. I don't know of any good projects right now, but I'll keep my eyes out. |
#7 | ||
frugal-phile(tm)
You need to hear a set of these then Quote:
dave
#8 |
For the entry price of $36.50 at Madisound, I'm intrigued. I already have an 0.38 cu ft enclosure from Parts Express. If I had an FE127 in this box with an aperiodic port, do you suppose I'd get the general idea of what's nice about these single driver speakers?
#9 |
frugal-phile(tm)
You would get the general idea. The rough edges on the drivers get smoothed over with driver mods. You'd have to shrink your box a bit -- but these MDF boxes really need some serious bracing anyway.
These ones? http://www.partsexpress.com/pe/showd...number=302-710 If it were a tiny bit taller it could be made into a foldeed diyAudio FR Ref ML-TL... it should be big enuff to squeeze a Fonken-ish design into. dave
#10 |
frugal-phile(tm)
[QUOTE]Originally posted by joe carrow
with an aperiodic port/QUOTE] The porting is a bit trickier than that, to get decent bass it need sto be nearly aperiodic. This is achieved by using a very high width to height ratio on a long port (i think i calced it at something like 50:1. dave
| Efficient Single Driver Bookshelf Speakers | pjanda1 | Swap Meet | 2 | 7th July 2009 10:43 PM |
| smallest sized, efficient bookshelf speakers for the Charlize? | hansel | Multi-Way | 3 | 11th April 2007 11:15 PM |
| efficient (loud) 'monitor'/bookshelf designs for 5.1 | Puggie | Multi-Way | 0 | 30th May 2006 10:17 AM |
| 1 efficient 12" or 2 (far) less efficient 10"s? | beady | Car Audio | 4 | 8th August 2004 04:55 AM |
| Efficient HF horn | Ilianh | Multi-Way | 6 | 7th January 2004 06:50 PM |
| Page generated in 0.14936 seconds (71.32% PHP - 28.68% MySQL) with 10 queries |
