Hi all,
I am in constant search fore the very special and cheap driver, and there never seems to be any luck ![]() But now I have got a suspicion that this Emminence Gamma-15 might work very well in Onken and seem to go quite low About 180 liter and sensitivity 95db up to 500hz - should work fine in a standard 3way, or maybe even with a fullrange Cost 73 EUR Any comments on that |
#2 |
Greets!
Only that the vents are still too long at the lowest Sd'/Sd factor = 0.75. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#3 |
OK, I should have known that 180 liter is too small with a 15" in Onken
It should be used in a standard BR, maybe with slot port and I reckon that will be very nice anyway GM, thank you fore evaluation |
#4 |
Greets!
You're welcome! Hmm, not necessarily, I assume you'll either need an inductor, which has some series resistance or you can add some to 'fill' a larger cab. That, or build an EBS alignment, which normally blends better with the room. Adding 1 ohm and n = 7 drops the vent length enough and tuning to the mid 30s, otherwise if space is the issue and ~42 Hz is low enough, then a MLTL is probably best overall. GM
#5 |
GM, what do you mean by "EBS" alignment, and "n=7", if its not too complicated to explain I guess with relative low Xmax=3mm, it should not be tuned too low I would like to build the thing, not that I need it really its not "for free", but from time to time I can see there is some demand for such a speaker, so at some time I might just do it, and hopefully find worldwide obtainable parts Midrange could be AltecLansing inwall CF404-8A, and maybe a BohlenderGreabender tweeter The 92-95db might come in handy when I build my small tubeamp |
#6 |
Greets!
EBS = extended bass shelf. It's a larger than normal cab tuned low, typically as low as 0.7*Fs to get a ~sealed low Q alignment except with more gain above Fb for best transient response and take advantage of some room gain to make it perform ~flat in-room to a lower effective F3. Onken alignments are defined by their 'n' factor, with 6.34 being the default and what the 180 L one is. Increasing it progressively increases Vb and decreases F3, Fb. GM
#7 |
Forgot, sorry...I might have calculated with lowering Fs from 33hz to 30hz
I would really like a new dustcap glued at the point where membrane and voicecoilformer meets, and maybe some stiffening in this area I really dont like when they glue the dustcap in the "middle" of membrane - is it to get the look of a bigger voicecoil, or have I missed something But then its not a beginners job, and hard to controll the effect with xo - midrange might need coating too, and it easily gets out of hand UPS.... suddenly not easy anymore will have to keep it simple and straight forward
#8 |
Greets!
Not AFAIK, the DC is used to shape/control its HF BW. GM
#9 |
Ok, I have two options at the moment - build a speaker with modified drivers solely fore my own use, OR make it purely standard fore anyone to copy (which would make it more fun)
If get any further with this I will be back with details Thanks |
#10 |
Project stopped permanently - I am told that theese drivers will have very high distorsion
![]() My NEW "love" is B&C 18PS100 if only it didnt have that peak.... and dual spider
| Onken, anyone? | cyclotronguy | Multi-Way | 155 | 28th May 2009 05:22 AM |
| Onken for 10" or 12" drivers. | maal1605 | Multi-Way | 1 | 29th November 2008 01:52 PM |
| Onken cabinet | The gun | Multi-Way | 9 | 11th November 2008 05:35 PM |
| Stuffing an Onken | jlsem | Multi-Way | 2 | 27th July 2004 11:27 PM |
| Page generated in 0.10874 seconds (75.44% PHP - 24.56% MySQL) with 10 queries |
