Measuring tweeter FR without a highpass filter
Old 14th March 2007, 01:10 AM   #1
owdi is offline owdi  United States
owdi's Avatar
Default Measuring tweeter FR without a highpass filter
I want to measure the raw in-box frequency response of my Seas 27TBFC/G and Vifa XG18. I would like to do this using a 170 ms long burst of pink noise at 2.83 volts, with a cutoff frequency of 100hz. The woofer will not be a problem, but I'm not sure about the tweeter. Can the tweeter handle this test without a filter? Should I raise the cut off pink noise frequency to avoid damage?
Search only turned up one thread:
http://www.diyaudio.com/forums/showt...008&highlight=
Dan
Old 14th March 2007, 05:30 AM   #2
soongsc is offline soongsc  Taiwan
soongsc's Avatar
The only issue I see is room resonances influencing the results.
Hear the real thing!
Old 14th March 2007, 05:39 AM   #3
owdi's Avatar
I will be taking gated measurements, so room reflections will not affect the frequency response. I need 170ms because that is the shortest measurement I can take in Arta. Only the first 6ms will be used.
Dan
Old 14th March 2007, 06:40 AM   #4
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
Measuring tweeter FR without a highpass filter Send a message via MSN to AKN
Hi owdi,
Yes, provided your conditions there should be no problem.
/ Anders
Measuring tweeter FR without a highpass filterHide this!Advertise here!
measuring RIAA filter accuracy robmil Solid State 0 14th September 2008 09:39 PM
Active highpass filter - ground skogs Analog Line Level 3 19th June 2007 07:25 PM
Measuring a Tweeter mikee55 Multi-Way 26 26th April 2007 01:59 PM
Tweeter highpass Khron Multi-Way 2 27th May 2006 02:41 AM
Highpass filter using sound card??? vsboxerboy Digital Source 0 18th July 2005 09:59 AM
