if the coupler in question uses a large initial wings gap - does it at some point lose loading small-signal and otherwise? It its vented towards the top then Fb can shift upwards a couple of Hz which might be difficult to see-saw by tuning a relatively small rear chamber.
I liked the tone of this coupler and 18" (or 15) with 1.2" gap a lot and not much at all with same wings swiveled in to provide a 5/8" gap. There wasn't a lot of difference in aperture area. Baffle angle was 23 degrees and port board canted forwards 10 degrees I had a notion that with outdoors ~ground plane plots that a tighter gap at the top could force more LF to the ground thus altering that perspective a tiny bit. http://img483.imageshack.us/img483/9605/gp12421lx7.jpg |
| Wide dispersion speakers using full (wide) range drivers | ozziozzi | Full Range | 1 | 28th December 2008 06:13 AM |
| cone loading as in Karlson ? | Empee | Multi-Way | 15 | 16th February 2007 09:14 PM |
| Help: Need to lose some volts | Decker | Chip Amps | 15 | 7th October 2005 07:47 AM |
| Anode Loading Vs. Cathode Loading ? | valveitude | Tubes / Valves | 19 | 22nd July 2005 10:00 PM |
| How much flux do you lose if... | 454Casull | Multi-Way | 11 | 18th January 2005 09:05 PM |
| Page generated in 0.07326 seconds (70.27% PHP - 29.73% MySQL) with 10 queries |
