Got a pair of Audax 25A tweeters, and has forgot which terminal is + (positive) and which is - (negative). There are no indication on the unit
They got one wide and one small terminal... Which is which ? Thanks in advance
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#2 |
On most Audax, (waiting for the
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
Did it Himself
Not sure I would check tweeters with a battery. Might be easiest just to see which way sounds best?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
I've never hurt one yet. I wouldn't use a 9V though...
#5 |
Thanks all
I try the small terminal as positive first
#6 |
I've never tried connecting a battery to a tweeter. Is it hard to see the excursion with only 1.5V? P.S. Martin. |
#7 |
every speaker I've ever seen that has a small and large terminal uses the large one as positive, and the small as negative.
#8 | |
Hi pinkmouse I usually use a 9 Volt battery with good results and the movement of the dome is easily seen. The DC resistance of the tweeter is ~ 6 Ohms , 9 Volts across 6 Ohms give 1,5 Amp ( if the battery is fresh enough... That will give a power dissipation of 9 X 1.5= 13,5 W , that the tweeter will take safely for briefs instants... Just my experience...
Jorge |
#9 | |
#10 |
Ok
Did the battery test anyway Small terminal on AUDAX A25 tweeters are - (negative)
| Decoupling Cap across the postive and negative pins | mudihan | Chip Amps | 6 | 17th April 2009 12:50 PM |
| 3 terminal regulator with 3 terminal shunt reference | BWRX | Power Supplies | 10 | 12th April 2008 03:49 PM |
| FE207E + terminal? | Lostcause | Full Range | 2 | 24th May 2007 08:31 PM |
| Spray-on postive resist (Positiv 20) in US? | gmikol | Parts | 6 | 10th November 2006 11:34 AM |
| Page generated in 0.10037 seconds (75.02% PHP - 24.98% MySQL) with 11 queries |
