Old 13th March 2007, 11:26 AM   #1
Lazi is offline Lazi  Romania
Default Help taming some frequency's
I own a pair of MA GR20.Many like their forward voices , but I have a problem.I am extrasensitive for sibilance , and the only way I can get rid of it is by cutting -6 or even -9 db from 7 and 10kHz.Now because I don't want to use an EQ , what I want to know is can I build some filter to conect the tweeter to it so I tame the sibilance , but only in that frequency range.
I already tried making acustical panel for my room , that helped but not too much.The amplifier is Creek 5350SE and CD is Creek MK2.So please if someone can help I'll apreciate.
Thanx guys!
PS Sorry if is hard to understand what I write , but i'm from Europe.I am a total beginner in the electronical part.
Old 13th March 2007, 12:00 PM   #2
All I know is I think I need a Notch filter , but that's about it.I plan a DIY with Manger , witch I've heard is much more layed back than regular speakers.A ZeroBox 109 for my 150square feet I think will be the best.
Old 13th March 2007, 08:30 PM   #3
What is a MA gr20 speaker, is it magnepan or monitor audio, please specify, in that case I can help more specific. Generally speaking you have to alter the xo filter of your speaker in order to change the response. However, you have to have some measurement capability if you want to do some serious efforts.
Old 14th March 2007, 07:40 AM   #4
The speakers are Monitor Audio , sorry for the confusion.I'm trying to obtain masurement equipment , but what I tell you about sibilance is clear.I don't care about the speakers liniarity if they hurt my ears.So trought a equalizer I heard a good sound when the 7,10kHz were down by 6db or even more.So that is what I need to obtain in order to enjoy my listennig.
In the meantime I think the solution is a parallel notch filter , and the values I came up so far are :
C = 3.73-3.9 uF, L = 0.09-0.1 mH si R = 7-8.5
Because MA are bi-wireble , I can connect this filter only for the mid-upper speakers , just before their crossover.
So if anyone can confirm this values , and the entire ideea , I will very much appreciate.thanks
Old 14th March 2007, 01:02 PM   #5
Hi, your values are correct, /sreten.
Old 14th March 2007, 04:07 PM   #6
Speakerholic
Cal Weldon's Avatar
The values may be correct but aren't you supposed to notch after the XO?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 14th March 2007, 04:26 PM   #7
Its a parallel LCR circuit placed in series.
Before / after the treble c/o will not matter too much.
/sreten.
FR taming tricks Moondog55 Full Range 25 4th December 2008 09:34 AM
Taming mains voltage cbutterworth Power Supplies 2 16th September 2007 03:50 PM
Taming the KSN-1141? Ovation Multi-Way 3 27th May 2005 09:27 AM
Measuring CCS impedance and at different frequencys Kevinbd Solid State 1 22nd October 2004 07:00 AM
taming the gc beast ss1 Chip Amps 6 29th May 2004 05:54 PM
Page generated in 0.09581 seconds (74.92% PHP - 25.08% MySQL) with 10 queries
