Old 13th March 2007, 07:17 AM   #1
zega55 is offline zega55  Croatia
zega55's Avatar
Question Speaker impedance
Hi people
I have a question and it goes like this
If I add a resistor in series with tweeter will I change his impedance (for crossover design)?
Ivan
Old 13th March 2007, 07:25 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Default Re: Speaker impedance
Originally posted by zega55
Hi people
Yes, of course.
Now, if you want to attenuate the tweeter without changing the load for the xover, you need a two-resistor attenuator that gives the required attenuation, while keeping the resulting load the same.
What is the tweeter impedance, and how much do you want to attenuate it?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 13th March 2007, 08:48 AM   #3
zega55's Avatar
I wanted know was I righ by saying that the load changes. Some people told me that I was wrong and it got me thinking so I asked. If I add a 2ohm resistor in series with tweeter his impedance will then be 8ohm. DC resistance of the voice coil is 4,8ohm (so it is a 6ohm speaker).
The midwoofer is 90db and tweeter is 91db so the attenuation of 1db is ok?
Thank you for your help.
sorry for my english I dont use it often
Ivan
Old 13th March 2007, 09:09 AM   #4
janneman's Avatar
Your attenuation is: 20 log (6ohms/2+6 ohms) = about -2.5dB in voltage.
Jan Didden
Old 13th March 2007, 04:47 PM   #5
zega55's Avatar
Jan Didden
this is a formula by wich it is calculated? That 2 in formula is the resistor I added in series with tweeter?
So if I add a 1ohm it will be:
20 log (6/1+6)= about -1.34db and will the tweeter impedance then be 8 ohm? Is their a formula for that?
Ivan
Overall speaker impedance erob Multi-Way 5 19th January 2009 09:04 PM
OPT impedance vs. speaker kvk Tubes / Valves 4 16th April 2008 05:37 PM
Speaker Impedance PhilR Tubes / Valves 8 21st December 2003 06:23 PM
Speaker impedance not what it seems? annex666 Multi-Way 9 8th September 2003 12:13 AM
Speaker Impedance RobPhill33 Multi-Way 2 14th January 2003 07:55 PM
Page generated in 0.09335 seconds (69.01% PHP - 30.99% MySQL) with 10 queries
