isosceles tetrahedron formula
Old 13th January 2003, 09:54 PM   #11
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
Default Re: Re: Re: Discrepancy
Originally posted by planet10
Mine was a guess pulled from my head (from info stored there a long time ago). If Rod solved the integral correctly then i probably just mis-remembered. Maybe the 1/6 should be 1/3?
dave
Are you SURE you're not thinking equilateral tetrahedron? Because if you're SURE that an isosceles tetrahedron is a regular solid, then my problems are over.
Dave
Old 13th January 2003, 10:30 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Re: Re: Re: Discrepancy
Ya i think i'm just out to lunch. Perhaps your use of the word tetrahedron made me not think it thru since it won't be a tetrahedron without having sides that are 4 identical equalateral triangles.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th January 2003, 10:49 PM   #13
kneadle's Avatar
I don't mean to laugh, but any four-sided solid is a tetrahedron. There's the equilateral tetrahedron, the isosceles tetrahedron and the true irregular tetrahedron.
I love this forum, though. You, in particular, are very helpful. I read a lot of your posts and, in the process, have learned a lot.
I'm still porting this design...
Dave
Old 13th January 2003, 11:06 PM   #14
frugal-phile(tm)
planet10's Avatar
OK, just call me out to lunch today...
I used to eat this stuff for breakfast (Honours Degree in Math)
dave
Old 14th January 2003, 12:11 AM   #15
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I'm thick...(and intrigued). Could you draw me a picture of what you are trying to achieve?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 14th January 2003, 12:40 AM   #16
kneadle's Avatar
Default Trying to imagine, first, not achieve
I have a pair of equilateral tetrahedron speakers, which have been destroyed in the course of history. I want to keep the tetrahedronal concept, but design them better. The picture is the front baffle with a 6 1/2" Vifa P17WG00-06 and a Vifa D27TG05-06 aligned.
There will be a total of 4 baffles (if this idea survives). The bottom one will be an equilateral triangle of 21" or so (it needs to be reasonably narrow). The other three are shaped exactly the same, like the one pictured, creating a reasonable volume in the shape of an isosceles tetrahedron to let the woofer speak. You basically see the front baffle, and that's it, as shown. However, as was pointed out, it's hard to come up with enough volume in a tetrahedron.
Right now I haven't bought anything but the drivers, so I'm only imagining. In fact, I'm quite intrigued by the T-Line concept, and would like to e-mail planet10 if he will not be against private e-mails.
Tetrahedra are soooo sexy, though. The wife wants them painted white with pictures of clouds and rainbows on them.
Dave
Old 14th January 2003, 12:44 AM   #17
pinkmouse's Avatar
Ahhh, now I understand! Pyramid Power!!
So will you be using them to keep your razor blades sharp as well?
Old 14th January 2003, 12:48 AM   #18
kneadle's Avatar
We're having a baby, so there has to be a foam ball on the tippy-top to prevent baby from impaling herself...
...or Daddy, when he's trying to open a window or get a book.
isosceles tetrahedron formulaHide this!Advertise here!
Isosceles ( A speaker project) ttruman Multi-Way 27 7th March 2008 11:08 PM
Q formula PeteMcK Multi-Way 10 17th January 2008 07:42 PM
Line Array Isosceles Trapezoid Question dc270 Multi-Way 5 3rd February 2006 06:25 AM
Tetrahedron output stage topology. Circlotron Solid State 25 3rd February 2005 10:19 AM
Anyone have the formula for... Rino odorico Multi-Way 4 22nd January 2003 04:07 PM
