The perfect loudspeaker (looks like the added file)
I trying to build a 4 way loudspeaker consist of 2x 12'' jbl paper cones 2x 7'' scan speak 18W/8545-00 2x 3'' ATC dome mid ATC SM75-150S 1 tweeter the famous scan speak ring radiator R2904/700000 Xo Frequencys 150 500 3000 Need help with passive xo !!!
nehoray |
#2 |
diyAudio Moderator Emeritus
Well, you're not going to find help for a 4 way passive xover in the fullrange forum!
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#3 |
The subject heading is also misleading (and pretentious). Good luck!
#4 |
Get all the drivers, put them in the cabinets and take measurments. Once you have frequency responces (on and off-axis) for each driver you can start to look at crossover values to achive the Xover points you want.
#5 |
This should be obvious, but I feel like it's necessary to credit the picture to ShinOBIWAN. Also, to me "perfect" is synonymous with saying this loudspeaker would have completely ideal characteristics for reproduction of the 20Hz-20KHz frequency range, be an infinitely small point source, and be omni-directional. I don't think the loudspeaker you are describing meets these characteristics.
#6 | |
#7 | |
#8 |
WMTMW offers exceptional vertical and horizontal dispersion.
A 4-way using 1st order crossovers is often the top design. A 3-way using 3rd order crossovers is often the volume design. Rockport Hyperion 13", 6", 28mm dome |
#9 |
A 4-way using 1st order crossovers is often the top design. A 3-way using 3rd order crossovers is often the volume design. Rockport Arrakis 15" on side, 8", 5, dome |
#10 | |
I'm not sure this guys intentions are honest, he's joked around in the UKfest07 website: http://uk.diyaudio.com/festival07/signup.asp |
| DIY loudspeaker vs. factory built loudspeaker | keyser | Multi-Way | 83 | 16th May 2011 12:27 PM |
| The 'Perfect' Box | wiredmonkey | Multi-Way | 6 | 12th May 2008 11:17 PM |
| digital compensation to make loudspeaker transient perfect | mazurek | Digital Source | 2 | 20th July 2007 07:05 PM |
| Page generated in 0.11275 seconds (80.46% PHP - 19.54% MySQL) with 11 queries |
