High Power Coax designs??
Old 11th March 2007, 04:47 PM   #1
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Default High Power Coax designs??
I am looking for some Coax drivers for stage P.A. monitor use. something that sounds good and is clean through the crossover area.
These need to handle high SPL's with ease. they will be limited to maybe 50-60hz on the low end and dont need to go above 10-15K.
I have been looking at the eminence coax drivers but the crossover point to there suggested "super" tweeter seems a bit high at 3.5K for a 12" woofer to get up to easily.
I need some low end and most P.A. woofers seem to be pretty shy on the bottom. so a 12 or 15" coax is going to have to do the trick.
A 15" would be my first pick the get the lowend but then i am concerned about what it can do at the top end before the horn kicks in. so maybe a 12" is a better way to go?
it might be possible to do a 10" coax with a 10" woofer. but then the cost and the weight goes way up....
Anyone have any suggestions?
Zc
Old 11th March 2007, 05:03 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I just picked up a pair of these. Unfortunately I can't tell what they sound like as I haven't played with them yet.
PA drivers often need an EQ anyway so I wouldn't worry too much how balanced the sound is.
They need an XO.
http://www.partsexpress.com/pe/showd...number=299-766
planet10 needs your help:
Let's help Ruth and Dave
Old 12th March 2007, 08:43 AM   #3
bohngus is offline bohngus  Italy
Check the coax from B&C (http://www.bcspeakers.com/), they have good response curve and low distortion, and some models have a low crossover point.
Best regards
Old 13th March 2007, 11:56 PM   #4
Brett is offline Brett
Brett's Avatar
One of the BMS drivers, or one of these.
http://www.assistanceaudio.com/15_Assaudcoaxial.html
Old 14th March 2007, 10:12 PM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
And there is BEYMA
High Power Coax designs??Hide this!Advertise here!
Best high efficiency coax - any suggestions? Defo Multi-Way 35 11th July 2009 04:28 PM
High End designs? jaholbro20 Multi-Way 3 15th December 2008 04:36 AM
High-end DAC designs? sidd0rs Digital Source 18 27th October 2008 05:17 PM
High Efficiency designs? EDDIEMUNSTER Multi-Way 36 9th May 2007 01:55 AM
Copyright ©1999-2017 diyAudio
