Old 10th March 2007, 07:21 PM   #1
lovitz is offline lovitz  Canada
Default Volume Displacement Calculation
How does one calculate the volume displacement of the driver in a vented enclosure?
Bassbox Pro is giving me this option, but I can't find anything on how to calculate it.
Thanks.
Old 10th March 2007, 10:28 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Default Re: Volume Displacement Calculation
Thanks.
I'm not sure I fully understans the question, but the volume displacement of the driver is always Sd*X, where X is the excursion of the cone (which is limited to Xmax).
The volume displacement of the system is larger around the helmholtz frequency, since most of the volume displacement is taken care of by the port. There is no simple formula that covers the entire frequency range for the system volume displacement as a function of driver excursion.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 10th March 2007, 10:33 PM   #3
Speakerholic
Cal Weldon's Avatar
or are you asking how much room the driver takes up in the box?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th March 2007, 11:09 PM   #4
oh don't tell me it's that easy Cal....haha or is it?
Old 10th March 2007, 11:45 PM   #5
Svante's Avatar
Ah, so there is a box i bassbox to fill in the volume displacement of the driver, and you are wondering what to put there?
Ok, could be that it is the room that the driver takes... Silly me.
Old 11th March 2007, 12:52 AM   #6
I think your right. I saw volume and liters and thought it was something different.
So all I have to do is convert millimeters to liters for that value??
Thanks again guys!
volume calculation Pbassred Multi-Way 7 5th June 2005 05:58 PM
displacement volume for 15inch holger honda Multi-Way 2 22nd November 2004 12:12 PM
Box volume calculation questions. Nappylady Subwoofers 2 29th March 2004 09:03 AM
Help with volume calculation andrew01 Multi-Way 2 1st July 2003 12:32 PM
Volume Displacement For SPL Chart kelticwizard Multi-Way 10 4th September 2002 04:49 AM
Page generated in 0.09022 seconds (71.57% PHP - 28.43% MySQL) with 10 queries
