got a pair of BO Beovox S45-2.
any mods on x-over? it sounds mighty good as it is really. any other info?
It is not you... you are it. |
#2 |
#3 |
I own a pair of S45-2 bought 10 Euros in 1999, they are installed in a small office room (2.5 m x 4 m).
As they sound pretty good, I did'nt even open the box. The Philips tweeter used to be one of my favourite circa 1975. The S45-2 became impressive when I add a Sokol's circuit (an adjustable transform for the bass) ahead of the power amp. The 8' Peerless bass driver with paper cone is a very capable driver. I also tested the very simplified version of Richard Brice's Francistein circuit which makes stereo more stable : I would recommand to try it with any pair of stereo speakers. |
#4 |
I may add that the S45 has a Baakgard crossover said to be phase linear. Bass and tweeter are crossed at 12 or 18 dB/o, the little médium driver being a "filler" filtered with slopes of 6 dB/o on either side of the crossover frequency.
#5 |
I know this thread is more than three years old - but others might Google it (as I just did).
Beovox S45-2 is a surprisingly good little speaker - and can be made even better sounding without to much work or expenses. The capacitors in the X-over network should be changes/replaced with some made for the purpose (audiophile type). Since it's only 3 capacitors per speaker (and all 15 uF) it won’t ruin you. I put Jantzen Cross Caps in mine - but others manufactures can be used. Suggestions to other modifications can be found at http://forum.beoworld.org/forums/t/32520.aspx Best regards - Claus |
#6 |
I know this is an old thread but I'm doing up a set of Beovox S45 - 2 ATM. Does anyone know what the resister values are?
| B&O BEOVOX M70-CrossoverSchematic | ROVSING | Multi-Way | 0 | 23rd January 2009 03:11 PM |
| FREE - Bang & Olufsen Beovox 5700 (UK) | Greg3333 | Swap Meet | 3 | 17th August 2008 12:11 AM |
| Page generated in 0.09661 seconds (68.94% PHP - 31.06% MySQL) with 11 queries |
