Old 9th March 2007, 11:15 PM   #1
sdclc126's Avatar
Default Zaph BATMM?
Just curious - if I wanted to make the BAMTM into a TMM (just think they look cool), what would I need to change on the crossover, if anything?
Thanks.
Soft Dome
Old 9th March 2007, 11:50 PM   #2
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Much important things actually, and without measuring it and simulating it again, you are heading to uncharted waters I am afraid.
Old 9th March 2007, 11:56 PM   #3
sdclc126's Avatar
Understood - now, if I wanted to go hog wild & build some big towers, maybe MTMMM, or MMTMM? Still same issues?
Soft Dome
Old 10th March 2007, 12:47 AM   #4
ruerose is offline ruerose  Canada
Best to find a kit that matches your end result desires. Modifing existing kits (even just cabinet dimensions) requires changes that you have to account for in the crossover.
Take a look around RAW acoustics web site for some larger kits.
I wouldn't modify John's kits. Jesus kills a baby kitten everytime someone changes his designs.
Old 10th March 2007, 12:57 AM   #5
Salas's Avatar
Those swapped configurations must be measured on tweeter axis that you have to aim to your seated ear level. As you understand each driver is going to give a different response and dispersion out of its own axis when in a new position relative to a new tweeter axis. The box diffraction is going to alter for each new center too. By swapping them around and using the same crossover network you just destroy all intended FR and lobes for the initial configuration. Each geometrical configuration is a study on its own. For such things you better have a digital processor and many amp channels so to be free and quick in experiments, calibrated measurement equipment also, so to know what's happening. For classic stereo setup you need to build 2X specialized passive networks (one for each geometrical version), using measurements and simulations as always.
Old 10th March 2007, 04:41 AM   #6
sdclc126's Avatar
Thanks for all the feedback - you won't get any argument from me on it!
I'll stick with the original - just gonna make it a floorstander - another cosmetic preference. In a small space anyway so it'll be more than adequate.
Soft Dome
Old 10th March 2007, 05:54 AM   #7
Send a message via AIM to joe carrow
One thing that you *can* do is make a bass bin with the BAMTM. Just don't change the original project, then add an active crossover between it and a big box of (sub)woofers acting as a stand. A pair of ported 8"s or 10"s crossed around 100 to 300 hz would increase the bass and dynamics of the whole system.
Old 10th March 2007, 12:53 PM   #8
RJ is offline RJ  United States
Pete Schumacher already has a crossover and design for a TMM;
http://s12.photobucket.com/albums/a203/pete_schumacher/
Pete can be reached on the PE board;
http://www.pesupport.com/cgi-bin/config.pl
I've built the MTMWW's and the TMWWWW's usin the DA175's.
Great sounding speakers!
Old 10th March 2007, 04:04 PM   #9
sdclc126's Avatar
Hi Joe - I currently have a small sub but have considered the integrated sub approach; I actually would like to ditch the separate sub idea altogether at some point and have everything built into the mains.
RJ - thanks greatly for those links - that's what I was looking for.
Soft Dome
I just built Zaph's HiVi B3s speakers... thanks a lot, Zaph! :) fjhuerta Multi-Way 21 23rd May 2011 10:46 PM
Speaker idea based on Zaph ZD5, thoughts please, Zaph? wigginjs Multi-Way 23 3rd April 2009 05:09 AM
Why has Zaph not gone pro? Spasticteapot Everything Else 6 11th January 2007 01:09 AM
Hey Zaph... JSprague Multi-Way 6 20th September 2005 04:38 AM
Page generated in 0.10688 seconds (74.93% PHP - 25.07% MySQL) with 10 queries
