Curved Small Thor Build
Old 18th March 2007, 04:44 PM   #21
Renron is offline Renron  United States
Renron's Avatar
Default Baffle question
I am going to attach the back today and then wrap the sides with the cherry laminate, my question is:
What are the proper steps (in order) to baffle assembly?
When does the baffle get painted?
Are the speaker cutouts Routed prior to painting?
Baffle Installed prior to or after painting?
Nailed as well as glued or glue only?
How close to the bottom of the cabinet should the Port opening be located?
Thanks for the help guy's!
Ron
You can see the thin layer of Bitchathane just under the bendy ply skin.
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 18th March 2007, 07:03 PM   #22
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Another layer Another step closer
Love the shadows thru the holey brace.
Originally posted by Renron I must say that for only a 1/16th layer of Bitchathane the cabinets sound has changed to a thwump instead of a knock when struck with knuckles, I am impressed with the difference. Baffle width is now Exactly 9".
Despite that the BBC advocated using similar, if the frequency of the thwump is considerably lower than that of the knock the bitumenum may well have reduced the performance of the box instead of increasing it. What happens when you hit it on the inside?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th March 2007, 01:34 AM   #23
Renron's Avatar
Planet 10, Dave,
Thanks for your input, I can't believe how much time I have put into these already. They are starting to look like speakers!
It sounds like I am hitting solid wood, it is a different sound than when I hit the outside.
Did I get the answer right???
I could not stand looking at it any longer and I took a dremel with a cutoff wheel to all the shiner nails poking through the inside wall. Looks much better now.
The back was ripped as a trapezoid at 24* then run through a joiner after scribing the edges to meet the plywood. I will test my veneer skills on the back of the cabinets first. Not today though.
Thanks for your help,
Ron
Old 19th March 2007, 03:27 AM   #24
frugal-phile(tm)
planet10's Avatar
That is a good sound... means that the box will impress those who think the knuckle rap test should make a dead thunk, but the inside (where it counts) won't know about it.
dave
Old 19th March 2007, 02:41 PM   #25
Renron's Avatar
Smile Thanks for the good scare
DAVE,
dave
Is the knuckle rap test worthless?
Whew! I thought I was going to have to skin it alive and start over....OK now I can ask, Why is that a problem? I always thought (from what I've read) that the cabinet was suppose to be as dead sounding as possible so as to not interject any resonance or tonal qualities of it's own?
The intersection between the ply and the MDF back trapazoid is so smooth it cannot be felt when you rub your fingers across the seam. ShinObiwan would be proud. So am I.
How important is the placement of the port? Should it be as near the bottom as possible? Or can it be up off the floor 2"?
Thanks,
Ron
P.S. Thanks for keeping an eye on me
Old 19th March 2007, 05:30 PM   #26
frugal-phile(tm)
planet10's Avatar
Default Re: Thanks for the good scare
Not at all. It is just commonly misinterpreted (and no thanx to what almost seems a conspiracy to promote MDF as "the best" material for speaker building)
1st off, knocking on the outside of the cabinet only tells you about the ouside (which in a simple box is pretty much the same on the inside) As you have discovered in a more complex box it can be different.
All practicle panels resonate. What you want is a panel that has a resonance at a high frequency (where there is less energy to excite it) and one that is hi Q (so that it is even harder to excite, and if it does get excited, the energy is quickly disipated).
A broad, low frequency thunk means the panel is storing energy, and usually results in the cabinet re-radiating enuff to bury low-level detail.
Curved panels put the panels under tension which push their resonance up, So does bracing (and this best run along the long dimension of a panel)
dave
Old 21st March 2007, 03:37 PM   #27
Renron's Avatar
Thanks for the explanation Dave.
In reference to a question I asked earlier, I found the answer in the "Clarity" thread by ScottMoose post #231
"Port = 3" diameter x 4" long. 4" from the base. Can be front or rear mounted." It took me a while to re-read that thread but I found what I was looking for. I'm starting to learn about MLQWR and length of baffle requirements (effects). Slowly.....
Most of my crossover parts (all upgraded) have arrived so I can build those while I wait for my drivers to arrive. They are coming by SLOW boat and mule team I think. Ordered from Zalytron about 3 weeks ago. The woofers are in, just waiting for the tweets now. I'll post pics when have something to show.
Ron
Old 21st March 2007, 04:23 PM   #28
Renron's Avatar
Question for ScottMoose, or anyone who can help me out, please.
In the original layout of the small Thor Scott prescribes "The port is on the front panel, 3" diameter, 4" long, positioned 4" up from the internal base. "
Is that to the center of the port or to the bottom of the port?
As measured from the internal floor of the cabinet.
Thanks,
Ron
Old 21st March 2007, 07:55 PM   #29
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Internal base of the cabinet to the centre of the port.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 21st March 2007, 07:58 PM   #30
Renron's Avatar
Roger, Roger....
Thanks,
Ron
Curved Small Thor BuildHide this!Advertise here!
Short Thor build mattmcl Multi-Way 137 18th October 2016 06:54 AM
Short Thor Build Thread imjatse Multi-Way 40 12th January 2008 02:24 PM
Here's another Thor (Small) greenie512 Multi-Way 26 3rd September 2007 03:56 AM
THOR with curved side walls? runer Multi-Way 1 3rd August 2004 01:30 PM
