Curved Small Thor Build
Old 19th January 2008, 01:25 PM   #101
rob3262 is offline rob3262  United States
rob3262's Avatar
Default Thor
Originally posted by Renron
Back to your question, I'm extremely pleased with the sound and feel it is balanced and not lacking in the bass department given the size of the mid-woofers.
Is a sub-woofer needed to fill in the bottom end when enjoying Eric Clapton or critical listening sessions? No.
Is a sub-woofer needed for HT? Absolutely, nothing beats the rumbling/shaking of the couch when the plane/car/explosion reaches it's crescendo.
A quick check with my RS (non calibrated) digital db meter says;
Hz Db
10 63
20 72
30 75
40 73
50 69
60 68
70 68
80 72
90 72
As you can tell the Xover design sucks at lower freq. response.
But...the speaker cabinet design ROCKS! Capable of 75 dbs at 30 Hz! That says a lot about SM and P10s design and their experience in speaker design. Even that I can hear/measure 10hz is a miracle.
Does that answer your question?
Ron
Edit: These are premium component Xovers as designed by SEAS
I will be rebuilding the Xovers when I get a few bucks to play with
Yeah, I guess!
Th results of an Active Thor should be interesting, getting away from some of the stock crossover issues. Are you going to build the HT Forum version of the crossover, or just tweek this one?
- Rob
Scientific Principle and Common Sense
Old 19th January 2008, 04:15 PM   #102
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Re your query Rob, it won't make any difference to driver placement. We're only interested in the vertical resonant mode, so providing the CSA of the line remains ~constant, then you can use whatever shape you like. The curved panels should be more effective at supressing unwanted horizontal resonances etc., but won't affect the tuning.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 20th January 2008, 01:03 AM   #103
Renron is offline Renron  United States
Renron's Avatar
ROB,
The HT version
Sorry for being short.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Curved Small Thor BuildHide this!Advertise here!
Short Thor build mattmcl Multi-Way 137 18th October 2016 06:54 AM
Short Thor Build Thread imjatse Multi-Way 40 12th January 2008 02:24 PM
Here's another Thor (Small) greenie512 Multi-Way 26 3rd September 2007 03:56 AM
THOR with curved side walls? runer Multi-Way 1 3rd August 2004 01:30 PM
