Curved Small Thor Build - Page 4 - diyAudio
Old 21st March 2007, 08:46 PM   #31
Scottmoose's Avatar
Narry a problem. Keep up the good work...
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 5th April 2007, 01:25 AM   #32
Renron is offline Renron  United States
Renron's Avatar
Default Slow but sure progress
The bases were designed and cut freehand with a jig saw then touched up with a belt sander. Finally routed with a 3/8 roundover. They are attached with T nuts so I can access the Xovers later.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 5th April 2007, 01:27 AM   #33
Renron's Avatar
Default Speaker clevage
Couldn't resist.
Old 5th April 2007, 01:32 AM   #34
Renron's Avatar
Prepping for veneer lay up. Iron on method.
I spoke with a rep. from Titebond and asked about veneering with Type 3 instead of type 2. He said there would be no problem with the glue in that application style, (heat activated)
Ron
Old 5th April 2007, 01:39 AM   #35
Renron's Avatar
Sneaking up on trimming the veneer after application. Follow the grain direction and it all goes well. Unfortunatly cherry grain runs both directions........Uh. OK then, go both directions SLOWLY.
All worked perfectly.
Old 5th April 2007, 01:41 AM   #36
Renron's Avatar
Getting closer to what we want.
Sanding with 220 after trimming within 1/8", sanding in one direction only from new to old veneer.
Old 5th April 2007, 01:41 AM   #37
MJL21193's Avatar
Lookin very posh
Old 5th April 2007, 01:46 AM   #38
Renron's Avatar
This is what I was looking for underneath those pesky overhanging veneer edges. Hooray!
This seam is so smooth I truly cannot see where one ends and the other begins. Very happy with how it turned out.
Ron
Old 5th April 2007, 01:57 AM   #39
Renron's Avatar
Gluing on the tops, any added weight helps. they will be trimmed with a flush bit on the router later. I wanted to protect the top edge of the veneer, it may be a while before I get around to staining and finishing the cherry veneer. I order Target waterborne ultma finish over 2 weeks ago from Homestead Finishing and still a no show. I'll call and find out whats up in the morning. It will probably show up via UPS or FedEx tomorrow.......go figure.
Ron
Old 5th April 2007, 09:47 AM   #40
Scottmoose's Avatar
As The Librarian would say:
oook.
Seriously impressive build.
Short Thor build mattmcl Multi-Way 137 18th October 2016 06:54 AM
Short Thor Build Thread imjatse Multi-Way 40 12th January 2008 02:24 PM
Here's another Thor (Small) greenie512 Multi-Way 26 3rd September 2007 03:56 AM
THOR with curved side walls? runer Multi-Way 1 3rd August 2004 01:30 PM
Copyright 1999-2017 diyAudio
