Hi all, this is my first post on this forum, but expreienced in other car audio forums. I am interested in building a new home theater MTM set up with dayton reference 7" drivers with their aluminim tweeter. Here is a link:
http://www.partsexpress.com/projects...mtm/index.html I know there are quite a few people on here with similar set ups, and I am wondering how you like it? Does anyone know of any similar set ups, different drivers, for a similar price that you would rave about? I listen to jazz, rock and roll, and of course will have this set up for a home theater as well. I am looking for something very crisp and clean sounding, good mid bass response, and not dull sounding. Thanks for your help |
#2 |
I guess I will chime in since no one else has.
Dayton is synonymous with value, especially when they are on sale! The DA175 is another popular less costly Dayton woofer for HT setups. There are many, many DA175 HT projects. Do you have a sub? For your namesake I'm guessing you plan on having a sub. What kind, and where do you plan on crossing your mains to your sub? Also, what kind of receiver do you have, and is it 4-ohm stable? Sounds like a fun project, Roger |
#3 |
Thanks Roger_Law. I already have a dayton reference 12 inch high output sub with the dayton 1000 watt plate amp, all mounted in about 0.9 cubic foot sealed endlosure. I am building the set up one piece at a time. I do have a receiver, but it is old and definately not what I will be using when the set up is finished. It is a pioneer 5 channel receiver, from the early 1990's. Not even sure if it is 4ohm stable, but that doesnt matter in that I will get a new receiver at some point that will match my goals. Thanks for the reply.
#4 |
oh, and one more thing, the sub is low passed at about 65hz on the parametric eq with bass boost set at 22hz to compensate for the smaller size enclosure.
#5 |
Lots of possible designs for these drivers in the HTGuide Mission Possible forum.
This one is MTM http://www.htguide.com/forum/showthread.php4?t=13969 |
#6 |
You asked about similar designs - here is one with a different and probably superior tweeter, alternative Dayton woofers, simpler crossover design, and lower cost:
http://www.zaphaudio.com/BAMTM.html
Soft Dome |
#7 |
That post in htforum is awesome, exactly what I am looking for. Looks like the Dayton reference is a driver that is raved about. Now, there are many different MTM designs. Some which are tuned for low frequency extension down to about 30hz in a larger enclosure. The one on PE website is tuned for about 40hz cut off. Is there an advantage over having a lower cut off with good low end extension? I already have a competant sub set up, and may not need that low end extension below 40hz in the MTM's. Any other advice would be appreciated. Thanks
#8 |
I think you want the lowest practical bass extension only without the sub. With a sub you can stick with the higher cutoff for your mains and preserve the midwoofers' XMAX and thus SPL for the midrange.
Soft Dome |
#9 | |
| Custom Home Theater Project in New Home, Opinions appreciated. | thadman | Multi-Way | 5 | 20th November 2008 12:40 AM |
| Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? | wigginjs | Multi-Way | 6 | 3rd March 2008 08:56 PM |
| 6 Wayne J Dayton Home Theater Speaker kits (woofers, tweeters, xovers) | wigginjs | Swap Meet | 0 | 27th February 2006 01:49 AM |
| Dayton 6" reference and dayton silk dome tweeter combo project...input? | nerd of nerds | Multi-Way | 4 | 2nd December 2004 05:36 PM |
| DIY Amp for my Home Theater | ccarrigan | Solid State | 19 | 25th November 2002 06:58 AM |
| Page generated in 0.10011 seconds (82.30% PHP - 17.70% MySQL) with 10 queries |
