I recently heard a pair of PMC TB2+ monitors and was quite impressed at the big sound from these small bookshelf speakers. Has anyone done a similar transmission line bookshelf speaker?? I believe PMC uses Vifa drivers.
PMC transmission line monitors |
#2 |
Looks kinda fishy to me, at first look I would think it is a highly compromised TL, hardly a true TL at all in fact.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
Looks like a 56" TL with a very small cross section. I listened to a pair of those years ago, I recall them being not bad.
Sean |
#4 |
PMC use their 'advanced transmission line' technology. So no, they are not the same as you would get from Martin's MathCAD sheets for example. Compromised? Actually, I don't think so, they seem to work VERY well!
I would suggest they might be modelling them as a small enclosure with a very long and wide port. Might be worth an experiment to see how such a speaker turns out. |
#5 |
Martin's worksheets should model this TL fairly easily. Its a constant CSA line with the driver offset slightly.
Sean |
| DIY ESS AMT Tower Trans-line | DHarris | Multi-Way | 0 | 25th March 2008 07:29 AM |
| Anyone here built line arrays using HiVi B3S | zobsky | Multi-Way | 0 | 2nd March 2007 09:17 PM |
| I've built some amps, need suggestions for a DIY preamp or line stage | jduffy | Tubes / Valves | 13 | 3rd January 2007 11:58 AM |
| usage of line out trans. | robertc | Tubes / Valves | 2 | 25th June 2006 02:58 PM |
| Line array for HT with built in powered woofs | elambert | Multi-Way | 0 | 27th April 2005 01:44 PM |
| Page generated in 0.07411 seconds (79.53% PHP - 20.47% MySQL) with 10 queries |
