Old 4th March 2007, 10:50 PM   #1
polkymon's Avatar
Default DIY hardware
Bought some plumbing parts from Lowes during a blowout sale and made a neat set of feet for a floorstander I'm making.
The caps press fit into the tees and an iron pipe screws into the tee. A couple of U-bolts and you have an incredibly strong base. Sanded and painted them then topped them off with a rubber drain washer and a drawer knob.
Also picked up some solid brass drain caps and made them into speaker terminals using these posts.
http://www.partsexpress.com/pe/showd...number=260-314
Raw parts in foreground.
IMG]Click the image to open in full size.[/IMG]
Old 5th March 2007, 12:37 AM   #2
pinkmouse's Avatar
I like the terminal plates, nice work! We only get cast iron or plastic over here though.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 5th March 2007, 01:01 AM   #3
polkymon's Avatar
The terminal plates normally would be an expensive ($25) piece to use but I got them for $1.25/ea, on clearance. I actually bought them for the plastic shallow funnel shaped piece it was attached to that I thought could make a waveguide.
The feet/caps aren't as bad at $2-$3 normally but the clearance was $.08 for the tees and $.03 for the caps.
A30 hardware Buhl Pass Labs 10 9th December 2010 09:32 AM
Finishing hardware loninappleton Full Range 20 30th October 2008 08:34 PM
CNC cut MDF service or hardware? Daveis Multi-Way 14 22nd June 2007 10:11 PM
Hardware?? lpd Tubes / Valves 5 6th March 2005 03:36 PM
Page generated in 0.08673 seconds (73.77% PHP - 26.23% MySQL) with 10 queries
