'm going to install the port tube that came with the kit this weekend. It's the CSS flared port - looks a lot like this:
I'm a little confused by the flanges at the back of the port. The flanges are 3/4" long - same as the wall material that I'm using. Should I cut the hole to the OD of the flange, or to the OD of the pipe, and then cut slots into the wood for the flanges to seat? |
#2 |
I would just notch the wood around the ribs while allowing the port to still press fit into the box. You should also used a sealant like silicone to make sure there is no air leaks.
#3 |
The flanges are to apply spring tension so I think you should make a hole to fit around them and press it in like that... I would be carefull with silicone as paint will never grip well to any residue of silicone on the wood... maybe 'sicaflex' or just superglue would work better...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#4 |
All I do is cut a hole slightly smaller than the diameter of the flanges and push the port home. Stays in nicely.
#5 |
We use these ports when we do cabinets for Bob at CSS.
Best thing to do CUT off the fins period.If not you only have less than 3/16" of mounting area to pit the ports on. This is OK but not the best.We cut the fins off these when we have to use them and then just drill a 2" hole and the ports are a nice tight fit. |
#6 |
Thanks everyone. I cut a 2" hole and then cut slots for the fins. Everything fits well, but I don't think it was worth it. Next time I would cut the fins off for sure.
Thanks for all your advice! |
#7 |
I know it's too late now, but...
How about running the ports inside-out? Installed from the inside of the cabinets, with the flared end inside the cab. You could run a round-over router bit around the inside of the tube after you glue it into the baffle if you wanted to maintain a flare.
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt |
#8 |
It's important to make that straight edge a flared one like Max suggest's
High outputs will reduce air turbulant noise flowing in/out of this area as much as possible. Regards David |
| Rear port and front port | barry.childs | Multi-Way | 10 | 27th February 2009 09:46 AM |
| Slot port vs circular port equivalence | Brisso57 | Multi-Way | 12 | 21st February 2009 02:38 PM |
| Single Port Vent Better than Dual Port? | Daveis | Multi-Way | 18 | 15th July 2007 05:12 AM |
| To port or not to port? Newbie with newly built mains | starquake | Multi-Way | 1 | 18th December 2004 12:51 PM |
| rear port vs front port | Jimmy154 | Multi-Way | 22 | 6th March 2004 08:38 AM |
| Page generated in 0.10336 seconds (75.39% PHP - 24.61% MySQL) with 10 queries |
