Old 3rd March 2007, 04:59 PM   #1
sorenj07's Avatar
Default Cerwin Vega D-7
Hi, I just got a pair of these on Craigslist. They sound amazing but I don't think the tone controls on the left speaker are working. The knobs feel scratchy and turn a lot easier than the right speaker's. The crossover looks OK (no busted caps) but I do see a few electrolytics. I was just wondering if anyone had experience recapping/tweaking the crossover. It also seems that the upper midrange driver on the same speaker isn't putting out much sound. Should I check for continuity, or is it more likely to be an issue with the crossover? Thanks!
Edit/Delete Message
Old 3rd March 2007, 06:15 PM   #2
Speakerholic
Cal Weldon's Avatar
The "knobs" may be damaged or may have a static build up. First thing you try is squirting some WD 40 in the back of the pot. Oops, did I say WD 40? I meant anti-static spray.
If that doesn't work do a resistance sweep and compare them.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd March 2007, 07:16 PM   #3
sorenj07's Avatar
OK, that sounds pretty doable. I anticipate rebuilding the whole crossover network in the future but for now I'd just like to enjoy them..
cerwin vega's millertyms Multi-Way 1 13th July 2009 03:29 PM
Cerwin-Vega D-7's sorenj07 Multi-Way 0 9th February 2008 01:10 AM
Cerwin-Vega 189 E bigandsexy68 Subwoofers 1 28th July 2006 04:22 PM
Cerwin Vega! jamerick Subwoofers 4 6th January 2005 01:35 AM
Page generated in 0.07383 seconds (68.50% PHP - 31.50% MySQL) with 10 queries
